3
This discussion topic has been answered Discussion topic: Low resolution fonts on Sky generated text
This message was authored by: PortlandBill
Has anyone else noticed that the fonts used on text such as the Guide (other than the highlighted line) and program descriptions are now relatively low resolution (pixelated)?
I get this all the time now, for about 2 weeks or so I guess. I thought it was all text but actually only seems to be Sky generated text as the subtitles supplied by the program makers seem OK still.
This message was authored by: Jporch316 Answer
Re: Low resolution fonts on Sky generated text
Not sure I have noticed this .... what screen resolution ias your puck set at in picture settings ? Maybe try a different res (depending on your tv) such as uhd or 1080i then change back to auto
Avatar for PortlandBill
Level 3 icon
Good shout - it was set to 576pixels for some reason. I reset it to 1080 and all is OK again. I put thanks!
I thought as much .... it's happened to one of my pucks before .....
