Discussion topic: Loss of wifi to sky puk
Message posted on 01 Jan 2025 09:51 PM
Message posted on 02 Jan 2025 07:46 AM
Re: Loss of wifi to sky puk
Who is your ISP?
Message posted on 02 Jan 2025 11:06 AM
Sky fibre optic.
Message posted on 02 Jan 2025 11:35 AM
Can you do a network speed test on your puck/s.
Launch Netflix on your puck (you do not need to be logged into it, if you do not use netflix) and scroll down the left menu to Get help.
Choose Check Network.
Would suggest running the test a handful of times between tests over say a period of an hour, to see if it varies.
What is your speed?
