Discussion topic: Lip Sync issues - Sky Stream
Message posted on 22 Jan 2025 07:39 PM
Fully agree with what has been said, and earlier today I disabled UPnP as I'm not a fan, despite most ISP routers have this enabled. Also could not see if UPnP on my setup had actually opened any ports (which I suspect would have been outbound only), which also makes me uneasy.
Not had time to fully test, but having UPnP disabled, and IPv6 disabled, it seems (touch wood) still to be working as I would expect.
I hope it stays this way, as it's like a new system!
Of course, could be totally coincidental, and a new firmware build has been pushed out and fixed it 😁😁
Message posted on 23 Jan 2025 07:49 AM
If disabling IPv6 and Enabling UPnP is the fix then this is a huge security risk.
You are basically inviting malicious actors to open whatever ports on your network they wish.
And with the uptick of IoT threats is one of the reasons UPnP is disabled on my network. Sky Glass worked fine, this lip sync issue has only been a problem for me since end of October, and UPnP has never been enabled on my network.
Message posted on 23 Jan 2025 11:25 AM
Lip sync issues
SKY seem to let all users try this that and the other hoping that one of us stumbles across a solution 😕 and have no input at all
Message posted on 23 Jan 2025 12:23 PM - last edited: 23 Jan 2025 12:24 PM
Hi all,
We want to thank you again for your patience whilst we investigate the issue with Lip Sync on Sky Glass and Stream. We understand that this has been frustrating and we’re sorry for the inconvenience this has caused. We thank you for sharing examples of the issue, these always help our Support Teams working hard behind the scenes.
On Tuesday we began rolling out software version QS034.023.02 to Sky Stream customers, and this morning have begun the rollout for QS034.023.04 for Sky Glass customers to improve the lip sync experience. The software update is a gradual rollout, where we expect all Sky Glass and Stream customers to have their new software by the end of January.
Thank you again for getting involved in this discussion and we will continue to monitor any feedback on this thread following the update.
I'll be marking this reply as the answer to the thread so more people see it.
Message posted on 23 Jan 2025 12:55 PM
Chloe
Can you please give any details on what the issue was please?
Bluegiraffe
Message posted on 23 Jan 2025 12:58 PM
I can confirm my firmware version is QS034.023.02P now
I assume that's not the new firmware, since it has the P?
Bluegiraffe
Message posted on 23 Jan 2025 01:06 PM
@Bluegiraffe that is the same firmware version as I have on my pucks which contains the fix. It seems to be working for me.
Sky rarely comment on fixes but we know this had a high priority and took time to sort so it wasn't simple.
Message posted on 23 Jan 2025 01:29 PM
Good to know thank you. I know most companies just do the old 'Fixed performance issues' note, would still be good to know some idea of the root cause, I am QC Lead at a software company when we push out software updates at work we would make some information available as to the fix.
But I guess who cares as long as we can start complaining about something else now 🤣
Bluegiraffe
Message posted on 23 Jan 2025 08:10 PM
Seems I'm still on the old version QS034.022.00P.
I assume there is nothing I can do to force an update?
Message posted on 23 Jan 2025 08:41 PM
Nope. It's a matter of waiting, I'm afraid.
Message posted on 23 Jan 2025 11:16 PM
Sky Stream lip sync and freezing
My Sky puk arrived today and I've plugged it in and connected via WiFi. However all evening the lip sync of programs we are watching has been out and also the picture keeps freezing for a few seconds. What am I doing wrong? I'm thinking of buying at Cat6 earthnet cable to see if it improves. If it doesn't I will be cancelling within my 31 days 😞
please help, thank you
Message posted on 24 Jan 2025 12:01 AM - last edited: 24 Jan 2025 12:02 AM
Re: Sky Stream lip sync and freezing
Hi @Balders2 The lip sync is a known issue and Sky started rolling out a fix for it on Tuesday. It takes a while to complete the rollout but every subscriber should be updated by the end of the month. I found that if the lip sync went out a quick flip to another channel and back again usually got everything back in sync.
One of the main reasons for freezing is the quality and speed of the Wi-Fi signal being received at the TV/puck and not that being received at the router. This can be checked with the Netflix App (Get help > Check network) and is often much less than you might expect. The minimum speeds recommended by Sky are as follows:
HD = 25mbps
UHD = 30mbps
HD + 1 puck = 30mbps
UHD + 1 puck = 35mbps
These speeds assume there is nothing else using up your bandwidth.
If your speed at the TV is borderline try connecting via Ethernet cable as you have already said you might try. An ethernet connection will generally only give you about 80-90mbps as the pucks only support an ethernet speed up to 100mbps but the signal is generally more stable than wi-fi which be can be effected by lots of different factors.
Good luck.
Message posted on 24 Jan 2025 12:10 AM
- Connecting the Sky Stream puck via ethernet to the router is a good idea if practical to do so; that's what Ive done.
- You need a consistent broadband connection speed at the puck of at least 25Mbps (30Mbps if you add an extra Sky Stream puck or watch in UHD).
- An easy way to check what connection speed your puck is getting is to go to Apps and choose Netflix, then select 'Get help' from the menu on the bottom left-hand side of the Netflix main screen, then scroll down and select 'Check your network'. After a few seconds it will show your connection speed.
- Lip Sync is an ongoing issue for some users and Sky say they are looking into it. See this thread https://helpforum.sky.com/t5/Sky-Stream/Lip-Sync-issues-Sky-Stream/td-p/4607728
If you go to 'Settings' at the bottom of your home screen and select 'Picture and sound', then choose 'Sound' you can change the 'Digital audio output HDMI' to 'PCM Stereo' and/or change the value of 'Digital audio delay HDMI' in milliseconds. Either or both of those changes may correct your lipsync issue if your broadband is up to the job of streaming.
Message posted on 24 Jan 2025 12:18 PM
I now have QS034.023.02
and the issue has changed but not gone away. Now every so often the screen goes black and it briefly says please wait while the program loads,
when it reloads the lips are out of sync, changing stations resolves the problem. I had changed the sound settings back to the default auto.
Message posted on 24 Jan 2025 01:55 PM
It's a nightmare. Sooner they bring an updated version of the puck, the better @JeffGall or we still going to hear that it's our ISP or network, when it's not.
Hopefully this announcement in February will be an advanced Stream puck!
