This discussion topic has been answered Discussion topic: Lip Sync issues - Sky Stream
Message posted on 11 Jun 2024 01:48 PM
Re: QS025 Lip Sync Issues
Just received Q28 update and was hoping it would resolved the lip sync issue. Sadly not, and had to revert back to PCM Stereo to be useable. Come on Sky as this has been months now and still no word!
Message posted on 11 Jun 2024 02:24 PM
@JasonLee I don't believe the new update specifically included a fix but it seems to have resolved the lip sync issue for some customers and not others. I am one of the lucky ones and have not noticed the problem since receiving the update and I have now changed my audio settings back to auto. I'm guessing it has something to do with individual TV/puck setups.
If my post has solved your issue please mark as an "Answer"
Message posted on 11 Jun 2024 03:39 PM
Ive been away for a few weeks and was hopeful updates may have solved the issue for me - sadly not - setting back to auto and the synch is miles out !! Back to pcm stereo for me .
come on Sky sort this out please
Message posted on 11 Jun 2024 03:52 PM
still no update come through for me so still on 1.2 and qs027 but "pass through" is still working for me and after a few days Eurosport 4K got in sync for the tennis,
hopefully it stays that way for their Olympics 4K coverage.
sky sports on 921 and 922 are a lot better, the low latency does seem to make it 20secs or so closer to live.....
Message posted on 11 Jun 2024 03:59 PM
This really needs to be worked out - being advised to just use PCM when you have a cinema set up is just not acceptable. There was no issue previously with Sky Q and apple TV works perfectly. I was told that quality was exactly the same as Sky Q when I switched which is clearly not the case and unless it gets fixed in the next few weeks I will cancel and use an option that isn't sky
Using Sky puck - new panasonic OLED TV and Sonos 5:1 system
Message posted on 11 Jun 2024 04:07 PM
@pauliem1 wrote:This really needs to be worked out - being advised to just use PCM when you have a cinema set up is just not acceptable. There was no issue previously with Sky Q and apple TV works perfectly. I was told that quality was exactly the same as Sky Q when I switched which is clearly not the case and unless it gets fixed in the next few weeks I will cancel and use an option that isn't sky
In case it is specific to certain brands of equipment - I had lip sync issues with my puck and a Panasonic OLED. Some days it would be in sync, other days it wouldn't. Switching between apps and audio codecs would usually cause sync to drift. There was no consistency to it.
I tried different HDMI cables, going direct from puck to TV then eARC to AVR and also puck to AVR to TV, but it still remained dreadfully inconsistent whether the puck was on Auto or passthrough.
I have had no such issues with an Amazon Firestick 4K Max, Apple TV 4K box or Manhattan T3-R Freeview recorder. All maintain lip sync without any problem on the same TV, hence why I got rid of Sky Stream rather than the TV.
Message posted on 11 Jun 2024 04:15 PM
Re: Sky puck lip sync issue
I am still waiting for latest software update
connecting the puck to soundbar hdmi in then earc out to tv's arc hdmi port seemed to solve my lip sync on the whole but it does still crop up now and then.
Sony kd49 9005xg
ht 8500 soundbar
70gbps internet
tbh the puck is not a great bit of kit and once my contract is up I will try and go back to virgin v6 box or buy Apple TV 4K and forgo sky sports uhd which is only real reason to bother with sky at all. 4K Dolby vision atmos is better on other platforms.
Message posted on 11 Jun 2024 04:23 PM
I will also get rid of sky stream when my contract is up but got another year!
£46 is too much as sports in UHD is its only selling point. (I only have sports on top of basic stream package)
plus it's super cheeky including Netflix at only 720p resolution not even 1080p.
Getting a few months apple for free was nice but does not outweigh how rubbish puck is!
i really hope someone at Comcast / sky is speaking with engineers etc to ensure next puck hardware is up to snuff!
Message posted on 11 Jun 2024 04:33 PM
I hate to be that guy - but I am not having any of these lip sync issues, however I do use a soundbar, if it helps anyone my setup is
Sky Stream > TV > eARC > Soundbar
Sky Stream Audio set to Passthrough
eARC settings on my TV also set to passthrough
Message posted on 11 Jun 2024 05:02 PM
@TechMaster wrote:I hate to be that guy - but I am not having any of these lip sync issues, however I do use a soundbar, if it helps anyone my setup is
What's the make/model of your TV and soundbar? It seems that it could be certain manufacturers' kit which is affected, as not everyone appears to have lip sync errors.
Message posted on 11 Jun 2024 05:26 PM
LG OLED C2 - Sonos Soundbar / no issues for me now
LG C2 OLED 55inch
Sonos Playbar
Virgin 1 Gig
Virgin Stream Box
Xbox X
Apple TV 4K
Amazon 4K Firestick Roku 4K Google Chromecast
Message posted on 11 Jun 2024 05:31 PM
The TV is a LG OLED C3 and sound bar is a samsung q900t
Message posted on 11 Jun 2024 06:17 PM
Great. Those LG OLEDs are popular so lets see if others with the same combo of TV & Sonos/Samsung soundbar get the same positive results.
Message posted on 11 Jun 2024 06:27 PM
could it be as simple as arc vs earc and having the puck going into an hdmi earc device and not an arc device.....
Message posted on 11 Jun 2024 06:31 PM
Just to clarify my Stream goes into HDMI 1 on the TV and my sound bar is on HDMI 2 on the TV which is eArc
