1607
This discussion topic is read only This discussion topic has been answered Discussion topic: Lip Sync issues - Sky Stream
Locked
This message was authored by: broadleyman
  • I can see the lip sync issues go back to january 24 .  I tried to adjust audio digital delay and that didn't work .  I rang sky and was told it was a known issue they were working on but with no resolution date .  I asked if i could complain and was told i could but they would tell me the same thing . That was over a year ago .  Last week i found a solution on Ai . Changed from sound option from ARC ( enhanced Audio Return channel) to Dolby Digital plus . I then found that adjusting audio digital delay worked .  I complained to sky online about  the original brush off and the fact i had suffered poor service and had to find my own resolution. Asked for a call back which didn't happen . Got a brush off email rang sky to escalate and was offered £25 the one months fee £47 we are now at impasse and next step will be to contact CICIS .  Sky make complaining hard work
This message was authored by: Bluemoon1
Hi all
I recently had problems with the sync of the sound, I found it happening on Channel 4catch up  app, but it was always during the ad break. It would be a good second or more out. I switched sound to PCM but it still happened and would have to turn sound bar off and on again to get it back to normal sync ..Having said that today it was all ok on 4 catch up..
This message was authored by: loughor
I mentioned in this thread that I was getting lip-sync probems with my puck back in December last. Since then, I ditched Sky broadband in April when the price rose, which you may do penalty free whether in contract or not. I quit because it never, or rarely, achieved the guaranteed speed  I did call in and had varied responses by the agents. The last one basically didnot give care so glad I managed to quit when I did. I went back ro Virgin Media. SInce going back, I have not had any lip sync problem in the ensuing four months.
One pther thing, not related to lip-sync (but I'm not posting again), the puck regularly started and said there was no wifi, despite wifi being turned off as I use Ethernet, as I had been advised by a Sky agent. I turned wifi back on and kept it on Ethernet. Now I only get it occasionally and it clears after a few presses of of the Home button.
I'm still not sold on the Stream puck vs VM's 360 though. The playlist allegedly records but no, it does not link access to all streams, but that is a whole other grouse 😄
But yeah, lip-sync seems to have been OK since getting of Sky's BB. Whether any other Openreach virtual ISPs would be any better, I don't know.
Moderator notes: Edited to remove foul langauge
This message was authored by: kendoe47
Hi All, I have recently changed my broadband supplier. I am now with Bfibre with a speed of 900Mbps download and 900Mbps upload absolutely rock solid. As for LypSync virtually gone away. Only faults now are screen stutter changing from program to adverts and the occasional screen freeze. I can live with these.
Certainly 100% better with fast Internet.
My setup is Hisense N7 55inch, Denon AVR- S660H, Sky stream puck. AVR connected by eArc. Sky stream by ethernet.
This message was authored by: ChrisLacey
I found scrolling right down to settings on the Sky controller, then Sound then cancelling Dolby and ticking 'passthrough' worked for me
This message was authored by: larky+marky
To the genius at Sky who thought putting the sound sync setting at the bottom of the page with NO picture to adjust the settings too...................well done numb nuts.
This message was authored by: Brett25
Lip Sync issue with Stream
Having lip sync issues with stream on both TVs (Hisense & LG), had Stream only a few months and its sooo annoying - despite resetting, sound changes etc - still jumps regularly resulting in speech being out with picture. Turing Stream off and on - resolves until the next time!!!
Any suggestions please - as regretting the change to Stream despite sales pitch when renewing contract!
Re: Lip Sync issue with Stream
Lip sync seems to be entirely dependent on individual equipment as some people maintain that they are not affected, whilst others find it constantly problematic.
I assume you've tried changing the audio output to PCM, DD+, or Passthrough on the puck to see if it helps?
TBH I was never able to get a reliable and stable lip sync on my puck, which is largely why I got rid of it. No other device I use had issues, only the Stream puck.
This message was authored by: Darren057
Sound dubbed
Sound is slower than the mouth s taking
Re: Sound dubbed
@Darren057
On what TV platform and is this live TV, recordings or downloads?
Re: Sound dubbed
On the sky puck
This message was authored by: Andy--
Lip sync issues
I have just switched to a sky puck.
I have a hisense TV and a sky sound bar. Every time I switch on the TV I have to reset the lip sync.
Do I need a new speaker system or should I switch to sky glass gen 2
Thanks in advance for help
Sync issues
I have sky puck and a sky sound bar.
My tv is a hisense.
The issue i gave is the lip sync is always out,
I have tried delaying but every program is different.
What is the best setup with hdmi cables and optical wire
This message was authored by: DaveyP1
Sky Stream Sound Out of Sync. What is the latest.
Hi All
I know there are many threads around this issue, but can see the main 106 pages one appears to have been locked.
We have been experiencing the issue for nigh on a year, since we had Sky Stream and the situation is getting worse not better.
Five times daily we are having to reboot everything
It is not.an internet issues, we are getting 273 MB download into the box, and yes we have tried all the sound settings hacks.
What is the latest feedback from Sky in terms of acknowledging that this is on going or that a fix is indeed in sight.
Thanks for any info and please do direct me to an active thread around this issue if one is on place.
This message was authored by: Dazzasky
Re: Sky Stream Sound Out of Sync. What is the latest.
@DaveyP1 wrote:
Hi All
What is the manufacturer and model number of your tv ?
Locked
Answered - Go to Answer
