Discussion topic: Lip Sync issues - Sky Stream
Message posted on 19 Dec 2024 08:14 AM
The issue is Glass is also affected, I see just as many issues on my Glass TV downstairs as I see on my puck upstairs which is connected to a 70" Philips TV and Sonos Arc.
The issue is there is a relatively easy fix which has been used by PC's for a long time which could be used to fix this, regardless of whether it's the audio or video first, the fix is to have a buffer, by having a buffer the audio can then be shifted in either direction by the user. Whether this kind of implementation is possible on existing hardware is a question for the development teams to answer. Glass and stream must have some limited storage capacity, but whether there is enough storage capacity to buffer 5-10 seconds of UHD video will need to be looked into.
But I don't think this is necessary, because this lip sync issue is a new problem which has only recently come about.
The question is, what has changed? Is it firmware or the broadcast stream?
I'll stick my money on firmware, as I've only noticed the issue on my Glass and Puck since the AirPlay update.
Message posted on 19 Dec 2024 10:40 AM
The lip sync issue is not recent. It is at least 10 years old and the puck has just inherited poor software/hardware. It started when ARC came out and affected Sky Q. The only solution I could fine that was consistent was to plug an optical cable into Sky Q and my soundbar. The issue still persists on Sky Q as I still need to use an optical connection.
Message posted on 19 Dec 2024 12:33 PM
In respect of Glass and the Pucks, it is quite a new problem.
While there might have been certain setups which would have naturally been affected, A recent update seems to have created issues for a lot more subscribers.
I've never had an issue with Glass or Stream until now and I'm 2.5 years in on the service. It's only been the last 8 weeks or so for myself.
Message posted on 19 Dec 2024 12:39 PM
The puck has within settings the ability to manually delay or advance up the delivery of sound. It's is a pain to use and in this day and age it should be done automatically.
They pitch The Sky Stream as a premium service at a price they are very proud of.
I have asked Which? Consumer Service to look into the matter from trading standards print of view. It is appalling the lack of information from Sky.
Message posted on 19 Dec 2024 01:18 PM
All these replies about sound bars
not everyone uses them. I have two pucks, livingroom has a sound bar with very little issues and incidences of lip sync issues ..but it happens
my bedroom tv is a completely different story with no sound bar, a 2 year old Sony TV and it's a daily thing with lip sync issues with absolutely no pattern .
I turned on the tv today with lip sync issues literally as soon as I turned it on.
I also came from Virginmedia and I'm shocked at how bad the issue is with Sky..
and yeah, I've tried every single thing offered by Sky and in this thread and yet it continues ...
I feel like we've all been had and Sky knows it's an issue but doesn't care .
Message posted on 19 Dec 2024 04:30 PM
Where is the setting to "advance" sound?
Message posted on 19 Dec 2024 05:27 PM - last edited: 19 Dec 2024 05:57 PM
The problem with all these different experiences is that different issues and reasons for issues often get conflated in forums like this. It's not accurate to blanket say 'Sky stream is broken' if your experiencing problems, as for some others they wouldn't have any major problems or perhaps technical enough to be able to work out conflicting issues in their setup themselves. That of course isn't excusing Sky Tech team for not being able to help certain customers adequately enough. I do certainly think there needs to be far better training in that department.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck; Build: QS040.024.00P; UI Version: 3.214.2 | Sky Broadband Superfast
Message posted on 19 Dec 2024 05:38 PM
@Markp777 wrote:Where is the setting to "advance" sound?
@Markp777 If you go to Settings > Picture & Sound > Sount and then select Digital audio delay HDMI you can adjust the sound delay. There is no specific advance function but I suppose you could argue that you can advance the sound if you had previously delayed it.
Message posted on 19 Dec 2024 06:00 PM
Ooo that's stretching it a bit there @Fothergill1 i know what you mean though
Message posted on 19 Dec 2024 08:36 PM
Out of Sync
Message posted on
21 Dec 2024
04:44 PM
- last edited:
24 Dec 2024
09:21 AM
by
Kelsingra
Sound and picture not together
Sound about 2 seconds in front of image. Turn off then turn on corrects it until next program change or channel change. (removed) will look to switch to another company if not sorted soon.
Moderator note: Removed inappropriate language
Message posted on 21 Dec 2024 06:31 PM
Stream visuals lose sync with Audio
I have to keep resetting the puck as the picture looses sync with the audio of the programme I'm watching. Happens daily on all channels. Constantly resetting is driving me spare.
Message posted on 24 Dec 2024 10:24 AM - last edited: 24 Dec 2024 10:31 AM
Re: Stream visuals lose sync with Audio
Hi @richcawley74 There are a couple of quick solution mentioned on the forum which are worth trying.
A quick flip to another channel and back again often get things back in syn as does rewinding for a couple of seconds and then pressing the back button to get back to live TV.
Also check your audio settings and try different ones. Passthrough and PCM seem to be better for lip sync issues.
Hopefully Sky will find a permanent solution soon.
Message posted on 24 Dec 2024 06:14 PM
This seems to be a known issue since April 2024. Are they any closer to finding a solution?
Message posted on 25 Dec 2024 06:07 PM
Doesn't seem like it. I have tried everything and it's the only device that has issues.
The support team did try to help but they can't fix what is really broken hardware/firmware.
We will happily leave our contract when it ends next month. Apple TV and the occasional Now TV will be plenty for us 👍
The lip sync issue has driven me mad (and generally the overall layout (it is somehow even worse than D+ 🤯), I won't miss it 😅).
