1593
This discussion topic is read only This discussion topic has been answered Discussion topic: Lip Sync issues - Sky Stream
Locked
This message was authored by: Zoltron
The issue is Glass is also affected, I see just as many issues on my Glass TV downstairs as I see on my puck upstairs which is connected to a 70" Philips TV and Sonos Arc.
The issue is there is a relatively easy fix which has been used by PC's for a long time which could be used to fix this, regardless of whether it's the audio or video first, the fix is to have a buffer, by having a buffer the audio can then be shifted in either direction by the user. Whether this kind of implementation is possible on existing hardware is a question for the development teams to answer. Glass and stream must have some limited storage capacity, but whether there is enough storage capacity to buffer 5-10 seconds of UHD video will need to be looked into.
But I don't think this is necessary, because this lip sync issue is a new problem which has only recently come about.
The question is, what has changed? Is it firmware or the broadcast stream?
I'll stick my money on firmware, as I've only noticed the issue on my Glass and Puck since the AirPlay update.
This message was authored by: koopie
The lip sync issue is not recent. It is at least 10 years old and the puck has just inherited poor software/hardware. It started when ARC came out and affected Sky Q. The only solution I could fine that was consistent was to plug an optical cable into Sky Q and my soundbar. The issue still persists on Sky Q as I still need to use an optical connection.
In respect of Glass and the Pucks, it is quite a new problem.
While there might have been certain setups which would have naturally been affected, A recent update seems to have created issues for a lot more subscribers.
I've never had an issue with Glass or Stream until now and I'm 2.5 years in on the service. It's only been the last 8 weeks or so for myself.
This message was authored by: Ian+McK
The puck has within settings the ability to manually delay or advance  up the delivery of sound. It's is a pain to use and in this day and age it should be done automatically.
They pitch The Sky Stream as a premium service at a price they are very proud of.
I have asked Which? Consumer Service to look into the matter from trading standards print of view. It is appalling the lack of information from Sky.
This message was authored by: BobbiElman
All these replies about sound bars
not everyone uses them. I have two pucks, livingroom has a sound bar with very little issues and incidences of lip sync issues ..but it happens
my bedroom tv is a completely different story with no sound bar, a 2 year old Sony TV and it's a daily thing with lip sync issues with absolutely no pattern .
I turned on the tv today with lip sync issues literally as soon as I turned it on.
I also came from Virginmedia and I'm shocked at how bad the issue is with Sky..
and yeah, I've tried every single thing offered by Sky and in this thread and yet it continues ...
I feel like we've all been had and Sky knows it's an issue but doesn't care .
This message was authored by: Markp777
Where is the setting to "advance" sound?
This message was authored by: Paul+Dray
The problem with all these different experiences is that different issues and reasons for issues often get conflated in forums like this.  It's not accurate to blanket say 'Sky stream is broken' if your experiencing problems, as for some others they wouldn't have any major problems or perhaps technical enough to be able to work out conflicting issues in their setup themselves. That of course isn't excusing Sky Tech team for not being able to help certain customers adequately enough. I do certainly think there needs to be far better training in that department.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck; Build: QS037.045.01P | Sky Broadband Superfast
@Markp777 If you go to Settings > Picture & Sound > Sount and then select Digital audio delay HDMI you can adjust the sound delay.  There is no specific advance function but I suppose you could argue that you can advance the sound if you had previously delayed it.
Ooo that's stretching it a bit there @Fothergill1 i know what you mean though
This message was authored by: LesleySh
Out of Sync
We have a Sky puck streaming box. Recently the picture is out of sync with volume on sky sports cjanel
This message was authored by: AGH24
Sound and picture not together
Sound about 2 seconds in front of image. Turn off then turn on corrects it until next program change or channel change. (removed) will look to switch to another company if not sorted soon.
Moderator note: Removed inappropriate language
This message was authored by: richcawley74
Stream visuals lose sync with Audio
I have to keep resetting the puck as the picture looses sync with the audio of the programme I'm watching. Happens daily on all channels. Constantly resetting is driving me spare.
Re: Stream visuals lose sync with Audio
Hi @richcawley74 There are a couple of quick solution mentioned on the forum which are worth trying.
A quick flip to another channel and back again often get things back in syn as does rewinding for a couple of seconds and then pressing the back button to get back to live TV.
Also check your audio settings and try different ones.  Passthrough and PCM seem to be better for lip sync issues.
Hopefully Sky will find a permanent solution soon.
This message was authored by: JeffGall
This seems to be a known issue since April 2024.   Are they any closer to finding a solution?
This message was authored by: Pikman
Doesn't seem like it. I have tried everything and it's the only device that has issues.
The support team did try to help but they can't fix what is really broken hardware/firmware.
We will happily leave our contract when it ends next month. Apple TV and the occasional Now TV will be plenty for us 👍
The lip sync issue has driven me mad (and generally the overall layout (it is somehow even worse than D+ 🤯), I won't miss it 😅).
Locked
Answered - Go to Answer
