08 Dec 2024 08:23 PM
@Paul+Dray wrote:On the odd occasion a Sky employee will post a message but these forums are for the customer community and not to be thought of as raising technical issues with Sky tech support. There are other channels for that. Admittedly it would be good but it's just not intended for that.
Out of interest, what are the other channels for raising technical issues (and please do not say it is the phone - that is a none starter and Sky know it for this sort of stuff)? Genuine question as it is not at all clear and these forums are what customers are directed to. This issue has been ongoing for long enough that if this is not the right place, then it would be worthwhile raising the issue over there?
08 Dec 2024 08:27 PM
Did you try this? I just posted it a few minutes ago as it resolved it for me...
Go to Settings > Picture and Sound > Sound> Digital Audio Delay and set it to 80ms. - may need more or less of a delay on your system...
Leave Digital Audio Output on Auto.
08 Dec 2024 09:48 PM - last edited: 08 Dec 2024 10:06 PM
Your online My Sky account website gives help guides and faq's.
Sky Chat Assistant on Sky.com + get more help: Chat With a Sky Expert
Online customer complaints form
Email: viewerR@sky.uk
And yes a Technical support department phone line. 03337592608
Now I'm not saying you'll get a full resolution to any problems you have but it hopefully all adds to them being aware of common customer complaints and service issues.
08 Dec 2024 09:49 PM
@Paul+Dray wrote:Your online My Sky account website gives help guides and faq's.
Sky Chat Assistant on Sky.comOnline customer complaints form
Really? Is that your answer? The Chat Assistant is as rubbish as any other from bitter experience. So your original answer about there being other avenues for technical issues is a bit of a none starter I'm afraid.
08 Dec 2024 09:58 PM
The other channels exist. Whether you get anywhere with them is another thing as I said but it doesn't change the fact of their existence.
The chat feature is not just the assistant one but also a Sky Expert Chat feature too that you get shown if you still need more help.
Look I'm just a customer like yourself too so be reasonable with me pointing out the options and drop the attitude. I've told you the other channels to follow , I didn't say I'd fix things for you.
08 Dec 2024 10:00 PM
@FunkyL they literally told you sky have a technical support phone number and an online customer complaints form. What more do you want!? Try ringing the technical support number.....
08 Dec 2024 10:03 PM
08 Dec 2024 10:09 PM
@FunkyL yes and had success with different issues in the past. You should try it instead of expecting others to do all the hard work for you.
08 Dec 2024 10:11 PM
I've used all the channels available in the past with varying degrees of success.
08 Dec 2024 10:12 PM
@Jonny16 Little point in phoning the service department they'll just blame the problems on either your TV, AVR or soundbar. Initially they said they would send out a new puck, when it didn't arrive I phoned again and was told that there is nothing wrong with Stream the fault lies with your Denon AVR. Next phone call I made was to cancell my subscription and send the useless bloody thing back.
Sky just doesn't seem to care and are quite frankly taking the wee wee and quite a lot of money which they simply don't deserve.
08 Dec 2024 10:13 PM
@Paul+Dray wrote:I've used all the channels available in the past with varying degrees of success.
I've had none. Just spirals and spirals of frustrating none action. I guess experiences differ. Regardless our experience of Sky's qualuty of serivce and customer service is enough that when our contract expires we are out of here.
08 Dec 2024 10:19 PM
Yeah for sure if you don't feel you've had satisfactory resolutions to issues you're facing and don't want to wait for things to improve then yep make your formal complaints and don't renew. Frustration is par for the course in this crazy world, not just with Sky TV sadly.
08 Dec 2024 10:28 PM
I only have audio sync issues on some channels (Discovery and HGTV being main cuprits)
Chaninging to another channel and back again normally solves it I have no Dolby Atmos, or soundbars, or lcheap HDMI cables.
Audio and video should be delivered in the same stream and there should be no reason for them to go out of sync, audio samples should be discarded when video samples are lost and sync should be retained.
Bluegiraffe
12 Dec 2024 04:34 PM
The lips of the actor and the sound are not in since
