1596
This discussion topic is read only This discussion topic has been answered Discussion topic: Lip Sync issues - Sky Stream
Locked
This message was authored by: Super+Anthony
Unfortunately @cliff53 yes far too many glitches at present. Really hoping Sky will sort it all out as it's a great item. I think we all understand it's a new product, but they need to look at the systems they use before bringing out new products and fully test everything
(Please Note: I am Neurodivergent )
This message was authored by: koopie
The same issue has been kicking about for years for SkyQ users. Sky say they are not to blame but it happens across all TV's and soundbars. They are the common factor. Sky, just fix it once and for all.
This message was authored by: cliff53
I agree. £48 per month is expensive to be a guinea pig
Steveboy
Q30 firmware was released to a small number of Sky Stream pucks overnight.
If all seems well, would expect it to be sent to all pucks soon.
It does have lip sync fixes.
So, would be useful for those who have had the problem, to check in your puck settings if you have Q30 and report back if it has helped with your lip sync issues.
I would suggest, when making the settings audio change from PCM back to a Dolby setting, to do a restart of the puck within settings before testing. Just to be sure that the audio option has been set correctly.
Fornthe restart;
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete.
I Myself, have never had any lip sync issues with my various TV and audio combinations I have.
Will update sort all the other issues out as well?
Do we know what this update is going to fix?
4 times in a row today it kept freezing on the home page and crashing and rebooting. On one occasion it did not turn back on. Yes Sky have accepted their is still an issue better them and HO (broadband) but it's taking an awful long time to sort. Really hope it can get fixed, because as I keep saying, it's a great product, but only if it works correctly
This message was authored by: agmbrasil
I'm having issues this morning with lip sync. I have had stream for over a week and it has been fine however this morning after a few minutes of being ok the sound drops and then comes back on but the sound being a few seconds behind the picture. I've tried selecting different outputs e.g. PCM etc. but I get the same issue. I'm connecting Stream to TV then TV to Home theater through ARC. Everything else connected works fine as this was up until this morning. Really frustrating.
This message was authored by: Bros123
Just thought I'd add my voice to this.
Got stream recently which I like but this lip sync issue is extremely annoying.
Get it together Sky.
Not good enough.
Along with other issues @Bros123  listed below that need sorting. As I and many others keep hoping, hopefully soon
Black screens
Freezing on menus
Puck closing down and restarting and not always turning back on
This message was authored by: Roger17
It appears to be the poor hardware that Sky provide reading all the comments on here, and all the software releases that have come out and not fixed the issue, if you are out of contract or about to go out of contract and still want the Sky product, look at NOW tv with an apple TV box or a native app on a smart TV, you wont find the  issues you get with Sky stream and the cost is lower and monthly contract if you want it. If this was a software issue surely Sky would have fixed it months ago.
@Roger17 That's exactly what I said to them on a call yesterday. I suspect that you are spot on and that it's a software issue and it's up to Sky to fix.
Have to say, I looked at now TV, on offer for £6.99. I chose one mth at £9.99, then cancelled straight away. Now, then offered me 6mths at 5.99 per month.
I get entertainment for my  month. As I'm trialling it. However, no streaming issues, no loss of signal, no lip sync issues. It's looking good.
My options now seem clear,  use Freesat 4k box for my TV and apps, use now TV for sky, with broadband on virgin. Cost will be about £55 to £60 per month. No sport though.
Steveboy
This message was authored by: Matt+Nunns
Any update on when this fix will actually be pushed to devices, it's now two months since we were told the fix is "coming soon", I know that's a subjective term, but I wouldn't call waiting two months with nothing particularly soon, especially when you're paying extra for Audi codecs you can't actually use!
@Matt+Nunns Like all the other current issues, I don't think we expect any time soon. It's all very frustrating the time it takes to sort everything out. There are so many issues outstanding. They really need to do more advanced testing when bringing out new products
This message was authored by: MrsRooney
I may be becoming a little pessimistic, but I rather suspect that in Sky's eyes the issues we are experiencing with voice sync are quite well down their list of commercial concerns. Why? Because the vast majority of Sky Stream users will have simple setups where the Sky puck is connected to their tv, and that tv provides both picture and sound. And there does not seem to be any problem with such a straightforward setup.
Those of us who have decided to adopt separate sound systems, whether a soundbar or a full 5.1 or 7.1 speaker system have unwittingly introduced a complexity which Sky is clearly having difficulty with. And since I suspect we are in a minority compared to the numbers of 'straightforward' Sky users, I fear there is a limit in terms of the resources that Sky are willing to commit to finding a solution to our problem.
I think the best hope is that Sky will introduce a mk II version of the puck and take the opportunity to resolve all the known hardware and software problems. Whether we could then persuade them to swap our mk I pucks for the mk II pucks is of course another matter. Either way, whilst it would be nice to think a solution is on the way, I for one am resisting the temptation to hold my breath!
Locked
Answered - Go to Answer
