1566
This discussion topic has been answered Discussion topic: Lip Sync issues - Sky Stream
Re: The sound is lagging
@Sandrashurgold Sky are working to find a solution to the lip sync issue.
Rather than having to read right through the very long thread Sky have advised as a temporary workaround to change your audio settings to PCM or Passthrough whilst the find a solution.
If my post has solved your issue please mark as an "Answer"
This message was authored by: Dpbraham
The sound is not in sync with the picture
i have a black box for sky stream. The picture is not in sync with the sound. Using the tv for receiving programs without the box is fine. Can you help with syncronising the sound with the picture?
This message was authored by: Marksman67
Re: The sound is not in sync with the picture.
I had the same problem.  I sorted it by changing sound from auto to pcm stereo.
Go to:
Settings, Picture and Sound, Sound, Digital audio output HDMI then change to PCM Stereo
Hope this helps for you.
This message was authored by: pingloss
Re: QS025 Lip Sync Issues
I experienced this when changing to Steam using a Sonos Playbase connected to the optical output of my Philips TV.
The best 'workaround' while also being able to keep all the advanced multichannel audio formats and not having to change the Stream audio format to PCM is to a HDMI audio splitter such as the one I have installed here:
https://amzn.eu/d/irOoYB7
This completely removes the audio delay on any channel by removing the extra processing hop that occurs when having the audio passed through the TV first.  The splitter I use is compatible with ARC/eARC or optical feeds into your external soundbar such as a Sonos etc.
I've recommended this solution to other people and they've confirmed the delay disappears on their equipment once the splitter is in place.
This message was authored by: Alastair4
Audio/video glitch
Hi I have spoken with sky twice regarding an issue we have where the audio and video suddenly jump out of sync. It can happen every 20 mins or only once a day. We also have really poor quality calls as witnessed by one of your colleagues a few days ago. Please advise Kind regards Alastair Mead
Re: Audio/video glitch
@Alastair4  What platform are you watching on that is having the sync issues?
It happens regardless of channel, app etc
@Alastair4  Is this on Sky Q, Sky Glass or Sky stream?
It's stream
This message was authored by: JasonLee
Just a heads-up guys that my puck Stream updated to QS027 which I was hoping would solve the sync issue. Sadly, Dolby Digital is still out-of-sync so had to revert back to PCM Stereo.
As it's been several weeks now since this issue surfaced publicly, I'm wondering if Sky can give an update as to manage expectations/provide a timelime to all affected users?
This message was authored by: cooter29
Has lip sync been fixed.
Was holding off ordering stream until the lip sync issue was fixed.
havent seen any complaints in last week or so
Can anyone confirm its been fixed with software update ?
This message was authored by: TTrodd
Tv voices out of sync
TV sound not syncing with programme.
This message was authored by: Jack152
Voice sound is behind the picture
Voices are behind the picture
This message was authored by: Padam_Padam
Re: Voice sound is behind the picture
It's a known problem that's been going on for weeks.
Sky say they are trying to find a solution but it's taking time. They suggest switching the audio output of your puck to PCM Stereo as a temporary fix. You will lose out on any multichannel sound by doing this though, so not ideal.
This message was authored by: AD5
Re: Audio lip sync problems
After two months maybe you already fixed it...
Shame no one from Sky bothered to answer your post as it is a known problem.
A workaround is to change the audio ouput settings to PCM Stereo and that should fix the problem.
It worked for us. Future software update is on the way apparently.
Answered - Go to Answer
