Discussion topic: Lip Sync issues - Sky Stream
Message posted on 24 Apr 2024 10:58 AM
Re: Why does Sky Stream appear to be out of sync specifically on BBC Channels
@Arthur2236 Welcome to Stream and the forum. The lip sync issue is known to Sky who have suggested that whilst they find a permanent solution you change your audio to PCM or passthrough (see post 77 above). Personally mine is set to Dolby Digital + and I don't see any lip sync problem.
This whole thread is related to the issue which started with an update a few weeks ago.
Message posted on 24 Apr 2024 11:10 AM
Thanks for help Fother's, I've done as you suggest and I've set audio delay on the Puck and my Sky Sound box, which links between the puck and the TV (Panasoonic 55F model). All seems to be OK.
Message posted on 24 Apr 2024 02:19 PM
Re: QS025 Lip Sync Issues
Random software update jump today from QS025.017.00P to QS027.508.00P
Anyone else?
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck: Sky OS 1.3; Build QS040.069.00P; UI 4.22.1; Platform Version 8.4p58s1 | Sky Broadband Superfast
Message posted on 24 Apr 2024 03:03 PM
@Paul+Dray Yes, that is correct. There was no QS026 update as it was rolled into QS027
Message posted on 24 Apr 2024 03:50 PM
@Fothergill1 wrote:@Paul+Dray Yes, that is correct. There was no QS026 update as it was rolled into QS027
Ok understand that. Presumably this update includes the fix for the lip sync issue people have been having? I've not had any problems myself using passthrough to my av amp so can't check for people
Message posted on 24 Apr 2024 03:58 PM
@Paul+Dray Like you I didn't see much in the way of lip sync issues but I have been experimenting with my audio setting today and so far have still not had any issues.
Message posted on 24 Apr 2024 04:34 PM
Unfortunately, the update hasn't solved the lip sync issue. Warning FYI: it actually changed my audio setting back to Dolby Digital from PCM Stereo which I was only using as the workaround; had to change it back to PCM Stereo in order to have a lip-synced puck!
Message posted on 24 Apr 2024 05:03 PM
My bad - the puck update I refered to is showing as QS025.017.00P - not QS027; that may solve the problem but not received it yet to try
Message posted on 27 Apr 2024 01:54 PM
Re: Sky Stream Lip Sync
We have the same problem, it only started recently.
Message posted on 27 Apr 2024 02:02 PM
@ondemand-done I don't know if you have read through this very long thread but if not to save you the trouble try changing your audio settings to PCM or passthrough. This has been recommended by Sky as a workaround whilst they find a solution.
Message posted on 27 Apr 2024 02:20 PM
Thank you - that seems to have made an immediate impact, and improved the sound quality. I have a basic set-up, just a stream plugged into a tv via hdmi.
Thank you
Message posted on 27 Apr 2024 02:25 PM - last edited: 27 Apr 2024 02:25 PM
@ondemand-done Glad it worked for you. I find that if I use PCM I get sound dropouts which I'm guessing is something to do with my soundbar. I have ended up using Dolby Digital + and have found that generally seems to work for me.
Message posted on 27 Apr 2024 11:19 PM
Re: Sound sync issues with sky stream
I have the same issue, tried restarting sky pick it was ok for about 5 mins then the sinc issue was back.
if you put the pick in standby and back on again the sinc again was ok but after a few mins the issue was back again.
Message posted on 27 Apr 2024 11:25 PM - last edited: 27 Apr 2024 11:26 PM
This is a known issue at the minute with Sky Stream. Changing your audio output to PCM in the audio settings as per this thread over on the Sky Stream Forum should resolve: https://helpforum.sky.com/t5/Sky-Stream/QS025-Lip-Sync-Issues/td-p/4607728
MikeAlanR
Message posted on 28 Apr 2024 10:41 AM
The sound is lagging
The sound lagging on all programs
