Discussion topic: Lip Sync issues - Sky Stream
Message posted on 09 Apr 2024 09:25 AM
Re: QS025 Lip Sync Issues
Morning all,
Our support teams have been investigating lip sync issues that may have been introduced by the recent software update. We believe we might have a fix for this but would like to test it.
If you would like to support us by volunteering to have the software patch sent to your Glass/Stream please private message me your MAC address (found in device Settings).
Message posted on 09 Apr 2024 09:57 AM
Chloe I have sent you a dm to test this.
will this roll out across all sky stream pucks?
Message posted on 09 Apr 2024 10:17 AM
I can confirm what others have said but using passthrough setting direct to tv hdmi>earc>soundbar seems to work fine, no sync issues witht that setup
Message posted on 09 Apr 2024 01:05 PM
I changed the puck audio setting from auto to PCM STEREO, and now sync is fine no problem after 3 days..
Message posted on 09 Apr 2024 01:14 PM
That's a workaround, not a solution. When you invest in audio equipment capable of Dolby Digital, you should be able to enjoy content in this format.
Message posted on 09 Apr 2024 01:23 PM
@Steve888 Your correct but if you look at yesterdays post 77 from @Chloe-W22 (Community Manager) she said it was only a workaround. She also posted again today (post 98 above). I won't reiterate what it says but there is an option to participate in a solution trial if you are interested 😀
Message posted on 09 Apr 2024 04:23 PM
Re: Sky puck lip sync issue
@Littletaffia wrote:In view of the discussions over the last few days I thought I'd better check on the lip sync situation. I have my puck hard wired to the router and by HDMI to a high end Denon AVC. Lip sync has been a problem but became more stable a couple of weeks ago. On checking the sync is perfect. Even watching without the AV surround being used, it does go through the Denon when using the TV speakers and again no sync issues.
However when watching Ch5 earlier this evening the puck decided to go to BBC iPlayer and would not respond to any of the controls on the remote. I was about the disconnect it from the mains when it shut itself down and restarted. How's that for a curve ball!
Sounds like you have things setup very similar to me. Puck > AV amp > TV. With passthrough on the amp handles the incoming audio stream, decodes it and all's pretty much inline.
My puck crashed the other night too. Trying to rewind a program and it just went black. Had to power off the puck myself though and back on.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck: Sky OS 1.3; Build QS040.040.00P; UI Version 3.268.1 | Sky Broadband Superfast
Message posted on 09 Apr 2024 04:29 PM
@Steve888 wrote:That's a workaround, not a solution. When you invest in audio equipment capable of Dolby Digital, you should be able to enjoy content in this format.
If you have decent audio equipment then you should really be using passthrough anyway as it should have better decoding ability than the puck.
Message posted on 09 Apr 2024 06:32 PM
Hahahahha. I literally lol'd at that 🤣. Absolute jokers. EVERYONE! UNPLUG YOU EXPENSIVE AUDIO EQUIPMENT IMMEDITALEY AND USE YOUR TV SPEAKERS! 👌 Who needs decent audio on films anyway 🤷.
Are you guys going to refund/credit for inferior hardware/software? Doubt it.
Message posted on 09 Apr 2024 06:34 PM
Stop defending Sky for absolute cr*p software. You don't even work for them so why defend them? Do you get free sky or something for being a 'super user'?
Message posted on 09 Apr 2024 06:42 PM
It still doesn't fix the issue. It slowly drifts out of sync or stops sending audio completely when you change channels (for me, anyway)
Message posted on 09 Apr 2024 06:47 PM - last edited: 09 Apr 2024 06:49 PM
I don't know what message this is a reply to @LS3Capri same as your 2 other above messages not sure who or what comment they are a response to. When you click on the reply button and it takes you to the reply form if you click on the " (quotation mark) symbol in the format icons above the typing box first it'll then put the message you are replying to in. Yes I know it should do this automatically like every other forum I've used but it doesn't so just have to get in the habit of clicking that " icon first before typing.
Message posted on 09 Apr 2024 06:50 PM
Sound is out of synch with picture
Since installing my sky pucks the sound is out of synch with the lip movement on picture
Message posted on 09 Apr 2024 06:51 PM
Ah ha! Thanks for that. Terrible forum also. Im
on many different forums and none are as bad as this 🤣
I was referring to your 'passthrough' post earlier... when I set mine to that, it slowly drifts out of sync until you change channels then back again, or sometimes just completely disappears. Have both TV and Puck set to passthrough on a Q990C
Message posted on 09 Apr 2024 07:00 PM
I’m having issues where the sound lags behind the picture, so when people speak it’s out of sync.
The only option in Sky Puck settings is to delay the sound even more (which obviously won't fix the problem). Can anyone help?
