1595
This discussion topic is read only This discussion topic has been answered Discussion topic: Lip Sync issues - Sky Stream
Locked
This message was authored by: Spannerman007
Re: Sky puck lip sync issue
Personally I would say no. The stock answer is that it's a problem your end , or that they have not heard of anyone else having the same problem....
This message was authored by: Mill4
Sky stream sound lagging
The sound is behind by a couple of seconds. Swapped puck and seems to be okay on the other just the one lagging
This message was authored by: Gaz1978
Re: SKY STREAM - New software build QS021.005.00P caused new audio sync issue
I'm having sound sync issues with my Sky Stream Puck as of yesterday too.
All has been fine for the past 6 months and then suddenly it's rubbish! I've turned it all off at the plug socket, left for a minute or 2 then rebooted it, and it has marginally improved but it's by no means great........super frustrating watching films!
My sound is coming straight out my LG TV speakers.
Any ideas or am I just dealing with what it looks like many others are oing at the minute????
COME ON SKY!
This message was authored by: Matt138
I have had the same issue start today.
This message was authored by: Cromby
Seem to have solved the issue......
Lip sync issue (slight sound delay) started yesterday. Tried recommended solutions and spoke to Sky tech team member. Seemed to fix the issue but went out of sync again shortly after having seemingly been resolved.
I ave just switched from auto to PCM stereo in the sound options (Settings - Picture and sound - Sound - Digital audio output HDMI - choose PCM stereo) as I am using the internal speaker system of my LG OLED.  I switched off Dolby option in the TV's settings.
This message was authored by: MichaelA1961
Turned on TV late yesterday and immediately noticed sync problem. Hardware hasn't changed so must be software. Changed setting Digital audio output HDMI to PCM Stereo from Auto and working fine.
Sky - you need to sort this out.
This message was authored by: Bob561
Sound sync
Since yesterday , 4th April 2024 sound across all channels is out of sync . In addition sound on many channels sounds like it's warbling - most annoying.
Thought it might have fixed itself today , 5th April , but still the same.
Tried usual on/off routines , resetting etc etc to no avail 😡
This message was authored by: Mark-1974
Lip sync on my sky stream is terrible, they just says adjust the sound settings... This just makes the lip sync get further out. Not happy at all!!!
This message was authored by: Mr221
@Paul+Dray
we have had the same problem since the new update two nights ago sky stream can you sort it out never a problem before
This message was authored by: MarieF1
The sync on my sky stream is out. I have tried changing to all the other settings and turned it off
I have tried turning off and on but still sync is not right
Exactly my experience 🙄
This message was authored by: andyt8765
As of yesterday having the same issue. Audio comes ~250 ms after the image on all sound settings except PCM stereo, but PCM sounds tinny. My PS5 is absolutely fine so it is definitely an issue with the Sky Stream puck.
My puck and PS5 are connected to my TV through HDMI, and my TV is connected to a soundbar through optical audio cable.
Hopefully an update is on the way to fix this, but changing audio settings to PCM stereo appears to be the best option at the moment.
This message was authored by: gszab1
I don't have any lip sync issues (using a Samsung Q990C soundbar with eARC), but they have finally fixed the picture freeze when switching between stereo and dolby atmos. Yaaay.
This message was authored by: Leewinter1974
Delayed speaking
When programs are on the voice isn't at the same speed
Locked
Answered - Go to Answer
