Discussion topic: Light & dark colour shift
This message was authored by: cl6rkee
I have a new sky puck, less than two weeks old.
When a scene changes on any programme or service the image/screen goes slightly lighter or darker.
It is plugged in to a Philips 65OLED759.
The HDMI cables are channeled through the wall, so can't be changed without a lot of messing about.
The TV also has a 4K Apple TV, Panasonic
DP-UB820EBK and PS5 plugged in using the same type of HDMI cables and all have no issues with the image.
If I login to any of the included apps on the Apple TV, there are no issues with the image either.
I have played around with the settings on the TV, but can't find anything that makes a difference.
can anyone offer any possible suggestions or solutions?
Thanks in advance.
This message was authored by: Jason-
Re: Light & dark colour shift
Posted by a Sky employee
Hello @cl6rkee, thanks for sharing your experience with your new Sky Stream Puck and sorry to see you're having some problems with the picture depending on what you're watching. I'll send you an invite to a private chat shortly and we can look into this for you.
Just look out for the colourful bubble to start the conversation. Please be aware conversations automatically close if there is no response within 48 hours. Here's more information on how Community Messaging works - https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147#M141
Thanks, Jason-
