Discussion topic: Issues with Sky Stream apps
This message was authored by: Timmywhizz
Message posted on 16 May 2024 07:01 PM
I have sky stream. The channel 4 app freezes every minute or so, making it totally unusable, discovery+ says I have the app through sky, and just need to log in, then when I log in, says I need to go to google to upgrade, cant talk to anyone on the phone, as it ALWAYS says high call volume,
This message was authored by: Jporch316
Find out more
Message posted on 17 May 2024 06:47 PM
Re: Issues with Sky Stream apps
Couple of things to try
first pull the plug for 10 mins .....
also in the settings menu there's an option for "refresh apps" - if you select this it normally works over a few hours in the background
