2
This discussion topic has been answered Discussion topic: I feel discouraged about setting up Stream.
This message was authored by: nmaketiwa
I recently signed up to Sky Stream and maybe I am just dumb but I cannot connect or even reach the home screen.I have tried to update the software but it keeps hanging.I spoke with the call centre and they exchanged my box and I am still  facing the same problems.How difficult or easy is it to sort out connection??I feel so discouraged.
This message was authored by: Fothergill1 Answer
Re: I feel discouraged about setting up Stream.
Hi @nmaketiwa  Generally setting up a Stream puck should be a simple procedure taking only a few minutes.  If you are able to, try connecting the puck to your router by an Ethernet cable to get you past the updating software stage if it keeps failing. Also, make sure you are signed into your My Sky account at www.sky.com  and that you are using the same email address that is registered to your account.
During the setup procedure you will be asked for a PIN number.  By default this is the last 4 numbers of your phone number registered to your Sky account.
The following is a link to a very short Sky video on the setup procedure:
https://www.youtube.com/watch?v=oxVeo8adcnQ
Hopefully you wont need it but the following link takes you to some basic help files if you encounter any problems: https://www.sky.com/help/articles/setting-up-sky-glass-help
Avatar for nmaketiwa
Thank you,I will try that today.
Answered - Go to Answer
