Discussion topic: Home page on sky stream gets stuck or freezes
This message was authored by Jonathanphillip This message was authored by: Jonathanphillip
Sometimes when I switched on puck the home page doesn't seem to work it freezes and you can't move up or down on screen with remote untill it releases itself Try a reboot might help
Re: Home page on sky stream gets stuck or freezes
@Jonathanphillip  Have you tried a restart of the puck.
Also try a power off for a couple of minutes, then power back on.
How is the puck connecting to your hub?
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
Jonathanphillip
Ethernet cable
@Jonathanphillip  Should be ok with ethernet, given the home is loading it's not a Networked standby issue, however I wold check it is flagged as on:
Settings --> Startup and standby --> Networked standby mode = On
Jonathanphillip
@GD1  yes it's  definitely on network standby mode on
