22 Feb 2024 10:34 PM
Hi can I get some one to operate sky stream please
22 Feb 2024 10:58 PM
@Vicky79 wrote:Hi can I get some one to operate sky stream please
No. I'm afraid Sky Stream is self setup, there are no engineers to set it up or operate it for you.
You basically connect it to your TV, turn it on & follow the on-screen instructions.
22 Feb 2024 10:59 PM
Posted by a Superuser, not a Sky employee. Find out more@Vicky79 what issues are you having?
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
22 Feb 2024 11:00 PM
It has failed to turn on please
22 Feb 2024 11:13 PM
Posted by a Superuser, not a Sky employee. Find out moreHave you connected it to your TV via the HDMI cable? You may also need to change the input source on your TV to HDMI if you aren't seeing anything on the screen.
When you turn the stream puck on at the plug and press the standby button on the underneath of the stream puck does a white light appear on the puck?
NOT a Sky Employee
