Discussion topic: Help needed with stream puck
This message was authored by: Chewi123
Was watching TV this afternoon and it just turned off, since this I have not been able to get it to start. Tried the hard reset and it's still not turning on. Any advice? Seems the app is down due to maintenance.
Re: Help needed with stream puck
Not sure exactly what you mean by you tried a hard reset.
If your puck is not turning on, you need to do the following as described in this Sky help article, namely step 4 recovery procedure.
https://www.sky.com/help/sky-tv/sky-tv-stream/fixing-a-problem-sky-stream/fixing-sky-glass-sky-strea...
