2
This discussion topic has been answered Discussion topic: Freezing in standby mode
This message was authored by: Ed456
Keeps freezing in standby mode at least once a week
This message was authored by: Fothergill1 Answer
Re: Freezing in standby mode
Hi @Ed456Your puck may just be losing the network connection when it is in standby so go into the Settings > Start up & standby menu and make sure that the option for "Networked standby mode" to ON.  I would also turn OFF the overnight power saving.  It's worth a try to see if it helps.
Avatar for Ed456
Will give it go thanks
