Discussion topic: Flat plug for sky stream box
This message was authored by Terriwilloughby This message was authored by: Terriwilloughby
Hi - is there a flat plug I can order as the plug is too deep behind my TV that is flush to the wall
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
Re: Flat plug for sky stream box
Nope.
The plug provided in the box with the puck is the only supported plug provided by Sky.
Sky Stream and Sky Broadband customer
Terriwilloughby
Ok thankyou, I'll have to look for an alternative that fits.
Personally i'd not recommend using a plug/power supply that doesn't come with the product. Don't forget the Sky Stream pucks since Feb 2023 are property of Sky that are loaned to the customer whilst they have an active contract.
