Discussion topic: Episode won't play on sky stream
This message was authored by: Huw3
Does anyone know why I can't play True detective season 4 episode one on my sky strean
This message was authored by: Deedee36
Re: Episode won't play on sky stream
@Huw3  are you seeing an onscreen message?
“Trying to help improve sky glass”
Avatar for Huw3
Yeah it said this program is unavailable please try again later..but it plays all the other episodes
@Huw3 try a reboot of your stream
@Huw3 Somebody else had the same problem yesterday and when I tried to play S4:E1 on my system to check it out it played correctly so this is a strange one.
Maybe report the issue to Viewer Relations at [email protected]
This message was authored by: marbleyarncake
Hey - I am having the same issue too, got five minutes in and it died on me and now won't load. Must be an issue with the boxset - on a chat with a Sky rep now.
@marbleyarncake report the issue to Viewer Relation at [email protected] The more people that do it the more priority it may be given.
I have to confess when I say it worked properly (see post above) I only played about 30 seconds to make sure it was working.  Maybe I would also have had problems if I had watched for a few minutes.
I have reported it to the agent who is reporting it back - the weird thing is the show works just fine on my Sky Go app so I'm watching it that way...
This message was authored by: K8-13
Same issue, how do I report it?
As per the information in @Fothergill1 post just above you need to email the Viewer Relation at [email protected]
This message was authored by: JoshGorst
Anyone get this resolved?? Mine is the same issue.
 @JoshGorst  - So the previous replies and suggestions in this thread would apply to you also
This message was authored by: EllaEvee__
Not working for me either ! Was really excited for a Friday night binge ! 🥲
Yes. Have emailed them as advised but reply is 3 working days so was just wondering if it's been resolved. Judging by most recent post. Clearly not. Very frustrating. Pay enough as it is for sky without issues like this.
