316
This discussion topic has been answered Discussion topic: Dolby Atmos audio drop out
This message was authored by: Castiel109
Re: Dolby Atmos audio drop out
My HDMI cables are already 2.1 48gbps. It's not that. Your solution simply doesn't work.
This message was authored by: Nigelb1972
@Castiel109 They're HDMI 2.0 then. HDMI 2.1 has over double the amount of bandwidth.
My solution works perfectly well but if you don't want to take the help, thats fine... You carry on in ignorance with your audio dropouts and I'll carry on enjoying Sky Stream in glorious UHD HDR & Dolby Atmos without any audio drops as I have been for over a year 👌🏻...
They're really not. All my HDMI cables are 2.1. As I said they have 48Gbs bandwidth. 2.0 is 18Gbps.
maybe know what your actually talking about before giving advice on HDMI standards.
While it might work for you, as this thread has proven, it doesn't work for everyone.
Ahh ok. Sorry I misread your post (dyslexic)... If all your cables are 2.1, check your settings and also that your TV supports eArc and HDMI 2.1. and also that your audio device supports DD+ because it definitely works.
This message was authored by: Dac20vt
100% doesn't work for everyone and to be frank, we shouldn't be having to botch a solution cos Sky can't come up with a proper solution or provide capable hardware.
Apple TV and NowTV is the way to go.
This message was authored by: Dazzasky
I agree, it doesn't work for everyone but the poster thinks they are right and everyone else is wrong, now that is what I call ignorance.
I've done everything you suggested. It hasn't worked.
I tried it on my G4 LG and my Marantz/Kef Atmos setup and also with a Sonos arc partnered with a G5 LG.
all with e-Arc enabled etc.
Sonos in fact was worse, with the dropouts lasting minutes rather than seconds.
This message was authored by: Scrumpet
Can I just ask and clarify that you have checked the speed to the sky stream puck? You can do it with the Netflix app. Worth a try. It uncovered for me a super slow speed that couldn't handle the high res image/sound. Alterations after that have helped for me.
Yeah. One of the first things I did. All my pucks are wired anyway and I have gigabit internet.
I've tried pretty much everything suggested in this discussion including moving the pucks and so on.
Wow - really bizarre then. I wonder if you've got faults in the hardware somewhere then? Don't really know what else to say. I guess keep badgering Sky? See if they'll send out an engineer or something? Good luck!
I think with the puck it's luck of the draw and I suspect that the internals are highly dependent on batch suppliers etc.
This message was authored by: AppisCrap
All these years later & Sky still haven't bothered to fix this issue.
Embarrasing.
This message was authored by: rw2012
It's driving me bonkers. Audio delay on every channel now in Stream. It's only slightly out by a few seconds.
Give me back the Sky Q box.
Avatar for gpb156
Level 3 icon
This message was authored by: gpb156
I have been away from this discussion for sometime and have just realised I don't seem to have audio dropouts on Dolby atmos now. Nothing different on my set up bitstream audio pass though to sound bar.
Wondering if this is the same for anybody else? Have sky secretly fixed it?
No can confirm it's still an issue.
Just had a long one where it said please wait for your programme to start and then eventually channel 4 came on but was a good five or six seconds out of sync with the video. Just using TV, not soundbar.
Answered - Go to Answer
