Discussion topic: Discovery plus error 400
Message posted on 17 Jan 2024 04:26 PM
Re: Discovery plus error 400
@Cleveleysbob wrote:Good advice, it's exactly what I did, unfortunately it didn't work for me, so reset was only answer.
Everything working fine now. Be nice if it lasts a while. 😂
That's a shame - I wonder why some need to do the reset.
i feel your pain having to login into everything again
Message posted on 17 Jan 2024 04:31 PM
Just factory reset mine, all back up and working.
Just be mndfull it does take a few mins for the blank screen to refresh, light on puk will flash red/green if it's loading.
Pain pairing apps back up.
Message posted on 17 Jan 2024 05:12 PM
Discovery plus
Discovery plus stopped working on my Sky stream , error code 400 says it's not connected to internet but all the other channels are working anyone having similar issues?
Message posted on 17 Jan 2024 05:36 PM
Re: Discovery plus
Have a little scan down the forum....
Message posted on 17 Jan 2024 06:07 PM
I've factory reset my sky as prompted and discovery plus is working now thank you
Message posted on 17 Jan 2024 06:23 PM
Hi
I agree I don't want to do a factory reset if it's not going to permanently fix the problem, as you have to sign back in to all your other services. I will wait until someone confirms this has actually worked!
Message posted on 17 Jan 2024 06:26 PM
@Paulsaunders1 Welcome to the forum. If you read some of the posts just above yours you will see that other than having to sign into your apps again this appears to have resolved the issue 😀
Message posted on 17 Jan 2024 06:29 PM
Mine is all up and running as they should after factory reset.
Message posted on 17 Jan 2024 06:31 PM
Error 400 no internet connection for discovery plus but TV connected through internet and that wNetf
TV connected to internet as have sky glass and Netflix working but requested discovery plus to be down loaded and cannot open as says error 400 no internet???????
Message posted on 17 Jan 2024 06:36 PM
@tonyang can I ask when you do factory reset do you have to reconnect to the internet, sorry to be completely thick.
Message posted on 17 Jan 2024 06:41 PM
Yes
Message posted on 17 Jan 2024 06:56 PM
Re: Error 400 no internet connection for discovery plus but TV connected through internet and that w
@Bakewell252 Please see the post marked as answer in this thread that is discussing the same issue on Stream, resolution applies to Sky Glass also.
Message posted on 17 Jan 2024 07:14 PM
Discovery plus states not connected to Internet
Message posted on 17 Jan 2024 07:24 PM
Thanks that works,
Message posted on 17 Jan 2024 07:53 PM
No problem for some reason sky boxes do strange things like that where for example you can get Netflix to work but some others don't yet they are all the same system
