Discussion topic: Discovery plus error 400
Message posted on 15 Jan 2024 05:21 PM
Re: Discovery plus not working
Actually I only have only 2 pucks one working one not working no idea why@
Message posted on 15 Jan 2024 05:28 PM
Re: Discovery + not loading error code 400
If you have a back up device such as a Firestick, Roku, or the app on your Smart TV you will Discovery+ still works🙂
Message posted on 15 Jan 2024 05:29 PM
So you think the problem relates to which sky server your puck connects to! Can you choose or change server?
Message posted on 15 Jan 2024 05:50 PM
If there was a fix that customers could do Sky would have communicated that on this forum as they have done with previous issues.
Once there is a fix or update the post tagged as "answer" will be updated by the Sky Commubity Team.
@DomBod wrote:So you think the problem relates to which sky server your puck connects to! Can you choose or change server?
Message posted on 15 Jan 2024 05:54 PM
Thanks for the link... I've tried the turning off for 10 minutes and all other things but still no good... anyone at sky or discovery care to help / assist?
Message posted on 15 Jan 2024 05:58 PM
@Himleyowl01 wrote:Thanks for the link... I've tried the turning off for 10 minutes and all other things but still no good... anyone at sky or discovery care to help / assist?
If you have read the link to the other thread you will see there is no fix. Just read the post marked as answer which will get updated on that thread as Sky have more information to share.
Message posted on 15 Jan 2024 07:10 PM
I have also had this problem and yhe only way i have been able to get it to work is by doing a factory reset i have had to do tis several times but it has only happened on my sky glass TV the streaming Pucks on other TVs have been fine
Message posted on 15 Jan 2024 08:13 PM
OK problem can effect sky q or stream puck. It does not relate to a location or IP address. A factory reset only temporarily fixes problem on either Q or puck but then within 24hrs same error 400 no Internet shows up. One theory says that one or more sky servers is effected with bug, other servers are fine and those apps connected to these servers operate correctly. Hope this helps the sky software engineers if they read it!
Message posted on 15 Jan 2024 08:59 PM
It began with us with our lounge puc, the dining room one was fine and the bedroom one. We changed over the puc in the dining room to see if that worked in the lounge , it didn't and now the puc in the dining room doesn't work either now! So far the bedroom still does.
Message posted on 15 Jan 2024 09:22 PM
If it was the server, how come I can get D+ on my lap top in the same room as the TV?
Message posted on 15 Jan 2024 09:26 PM
Now both my pucks can't get Discovery plus. Still get it on smart phone and desk top though
Message posted on 15 Jan 2024 09:53 PM - last edited: 15 Jan 2024 10:36 PM
Sky Glass/Sky Stream
It's not the same setup as using a streaming apps on other devices Laptop/FireStick/Apple TV 4K box /Chromecast with Google TV 4K other smart Tv's etc as the apps are stored on those devices itself
That is how you yourself can add or remove a app on those devices
Apps on Sky Q/Glass/Sky Stream are hosted on a Sky Server not the device itself that is why you can't add or remove apps yourself
There is multiple Sky Servers that provide connection to a providers app content that is why some customers are not having connection issue as their Sky Glass/Sky Stream get routed to a server that is not having a issue.
Sky/Discovery + need find what servers are affected to do a fix
That can be a simple fix or complicated
It might also be a Sky server with discovery+ corrupted file
Message posted on 15 Jan 2024 10:32 PM
Guess what Sky are still claiming there are no service issues to their streaming services despite the thousands soon to be millions with the Discovery plus problem
Message posted on 15 Jan 2024 11:09 PM
I reported this issue last Friday and was told it was an issue and had been escalated. The issue is however still not mentioned on the main Sky website as a service issue! The cover up is always worse than the problem!
Message posted on 15 Jan 2024 11:26 PM
I alo have the error code 400 no Internet connection whilst trying to log into my discovery + app. Glad I've seen this thread and know its not just me now. I'm on a sky glass TV. So annoying and hope they fix it ASAP.
