5
This discussion topic has been answered Discussion topic: Correct way to get Stream to turn on
This message was authored by: darling412001
What method does everyone use to get the puck to turn on? I generally press the home key and that brings my puck and TV out of standby but occasionally it doesn't work and I have to power cycle the puck.
Sky Stream
OS 1.3
Build QS040.058.00P
UI 3.309.0
Platform 8.4p58s1
Hardware IP061-ef
TV Sony A95K
AV Sony HT-A9
Broadband Hyperoptic FTTP 1.0Gbps
(Ethernet connection to Sky PUK)
This message was authored by: lettice Answer
Re: Correct way to get Stream to turn on
Have always used the power key top left on the remote.
It has not failed yet to turn on either of my pucks since Feb 2024, turning on Puck and then powering on its connected TV to the correct hdmi source.
When it does not work, do you get any kind of error?
Assume you have the preferred settings on your Sky puck, set as follows;
Set Network standby mode to ON and Overnight power saving to OFF.
Avatar for darling412001
Level 4 icon
No error message it just seems to not respond to home key.
Sky Stream
OS 1.3
Build QS040.058.00P
UI 3.309.0
Platform 8.4p58s1
Hardware IP061-ef
TV Sony A95K
AV Sony HT-A9
This message was authored by: Stephen+Mourton
@darling412001  I must admit I have never in the months of having Stream ever tried to switch on with the home button, but just tried it and it does indeed turn it on but obviously doesn't turn it off.  As has already been mentioned the top left on/off button is the one to use.
This message was authored by: Dazzasky
I've always used the home button and it has never failed.
