Discussion topic: Controlling TV Volume
Message posted on 26 May 2024 02:24 PM
Hi,
New stream user, and I'm having a problem with controlling my TV with the remote.
I had the box setup on my Sony TV, controlling volume and power on the TV no problem. I moved the box through to the other room last night (don't have enough boxes for all TV's yet as I'm still deciding if I want to keep it), I then set it up to control my LG Tv with Sonos playbar.
This worked fine.
I have moved the box back through to my Sony TV and ran the remote control setup again, and none of the settings seem to be working with my TV? I've ran through all the automatic ones (32) and then selected my TV manufacturer and ran through them too (12).
Nothing seems to work. Any ideas apart from resetting the box?
Message posted on 26 May 2024 02:27 PM
Re: Controlling TV Volume
Maybe try and reset the remote
The remote can be reset and paired again following these steps;
- Press and hold 7 and 9 together on your Sky remote for three seconds.
- Press and hold 4 and 6 together for three seconds.
- Press and hold 1 and 3 together for three seconds and follow the on-screen instructions.
Message posted on 26 May 2024 02:55 PM
I've just done this, and now I can't control Sky at all. Nothing is showing on the screen to repair it?
Message posted on 26 May 2024 03:18 PM
Ok, I didn't realise that I actually needed to be pointing at the IR port of the box to initiate the Bluetooth pairing.
Paired again, but still not controlling the TV for some reason.
Message posted on 26 May 2024 03:30 PM
You mentioned a Sonos system earlier - is it still paired to this as this may affect the pairing with your tv
can you delete the pairing with the Sonos ?
Message posted on 26 May 2024 04:29 PM
I wasn't sure how to go about that.
I did a factory reset and all seems good now.
