Discussion topic: Continuous tech fault
This message was authored by: Rhian12
I have been trying for days to watch sky Atlantic. I have sky stream not sky Q.
In the midst of watching it stops and says tech error try  again later.
I turn the router off wait then turn it on again. Appears to work, then 20mins later same thing happens tech error.
Really fed up because spending more time turning off and on than watching Sky TV.
Dont know what I'm paying for.
Re: Continuous tech fault
Should have posted this in the Sky Stream forum then. I'm sure an admin can move it.
@Rhian12
Post moved to correct board.
This message was authored by: Jporch316
@Rhian12
Thisnseemsnto be a common issue accross some users at the moment ..... sky have been notified
temp fix is to restart the puck
As mentioned above.
As seen on this community, some customers were recently getting a  'technical message', that from recent updates and changes now seems resolved.
If you have not done so already would suggest trying a restart of your Sky Stream box
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete
