Discussion topic: Continually freezing and error message there is a technical fault. Please try later
Message posted on 14 Mar 2024 08:04 PM
Sky stream is continually either freezing or showing blank screen with message : There is a technical fault. Please try later
I
Message posted on 14 Mar 2024 08:12 PM
Re: Continually freezing and error message there is a technical fault. Please try later
Have you tried unplugging it for a couple of minutes?
if that doesn't help , how do you have it connected to the internet via WiFi or Ethernet cable?
Message posted on 15 Mar 2024 09:33 AM
What is the connection speed between your router and Puck?
You measure that using the Netflix Network Check on your Puck😉
Message posted on 15 Mar 2024 09:44 AM
@Exiled-in-HH wrote:What is the connection speed between your router and Puck?
Assuming of course the Netflix app will open 😀
Message posted on 15 Mar 2024 11:25 AM
If it doesn't open then there is an issue that should be reported to Sky nott the Sky Community Discussion forums🤔
