Discussion topic: Connecting stream via wifi.
Message posted on 17 Feb 2024 11:04 AM
As sky stream can be connected via wifi. What is feasibility of using mobile phone tethering as a source if no broadband is available. For example to use aboard canal boat which does have power for the puck.
Message posted on 17 Feb 2024 11:12 AM
Re: Connecting stream via wifi.
If you are trying to use the stream puck outside the registered address you would be in breach of the T&Cs. Sky have monitoring available where they can see if a stream puck is essentially being used as different geographical locations.
At the registered address, using a 4G/5G enabled device is certainly an option as a backup for a broadband outage, however it will likely consume the data rather quickly so probably isn't advisable for a long period.
Message posted on 17 Feb 2024 11:23 AM
As @MarkGoldsmith indicates, if the boat isn't the postal address where the service was ordered then that's a breach of the T&C's.
HD on Stream runs at a rate of several gigabytes per hour, so a generous data allowance would be required.
Message posted on 17 Feb 2024 03:54 PM
Would they be able to tell if I took it through my 5g ? If I connect at home on mobile and away - surely they wouldn't be able to geolocate me as they do on broadband ?
Message posted on 17 Feb 2024 04:56 PM
@mirrors90 wrote:Would they be able to tell if I took it through my 5g ? If I connect at home on mobile and away - surely they wouldn't be able to geolocate me as they do on broadband ?
As the terms and conditions prohibit this you shouldn't do it
Message posted on 17 Feb 2024 05:14 PM
The curiosity got me , so i googled the implications - they will charge you £26 every month - depending on how long you watch from outside your house.
I guess thats to stop me from posting a puck to someone else and then they get "free" sky.
Message posted on 17 Feb 2024 05:20 PM
@mirrors90 wrote:The curiosity got me , so i googled the implications - they will charge you £26 every month - depending on how long you watch from outside your house.
Yeah that's essentially the reason. I believe the T&Cs also mentions they may terminate the subscription and account as well if they decide to.
Message posted on 17 Feb 2024 05:24 PM
Makes sense.
Sky are subject to rightsholders contracts so have to be very active on this
