Discussion topic: Cannot set up puck as remote input not recognised.
Message posted on 03 Apr 2024 05:04 PM
I took delivery of my new Sky Glass this morning and a new puck for my bedroom.
When i went to set the puck up it doesnt recognise the input from the remote so i cannot go through the setup process.
Is there a pairing process that needs to happen.
I couldnt see anything in the documentation.
Message posted on 03 Apr 2024 07:11 PM
Re: Cannot set up puck as remote input not recognised.
Hi @MDooler
The set up should guide your through pairing. Is the back light on the remote illuminating? It could be that a bit of the paper tab has stuck. Take the back off and check.
You can try unpairing and repair as per this article: https://www.sky.com/help/articles/remote-control-help-sky-glass
MikeAlanR
Message posted on 03 Apr 2024 07:42 PM
All I have is the let's get connected screen that I can't move past as the remote doesn't work.
Message posted on 03 Apr 2024 07:44 PM
I have managed to pair my old sky q remote so must be a duff remote
Message posted on 03 Apr 2024 08:49 PM
Hi @MDooler
As the puck is loaned to you, Sky will provide a replacement if you speak to customer services or there is an online form: https://www.sky.com/help/forms/streaming-tv-remote
MikeAlanR
