Discussion topic: Can’t stream amounting with sky puck
This message was authored by Msdrury This message was authored by: Msdrury
I have just set up my sky puck, I am using wireless connection but can't stream anything. Just getting a message saying
"please wait for your programme to load not working"
Need help fixing this issue.
many thanks
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: Can’t stream amounting with sky puck
I'll move your post to the appropriate board @Msdrury
▪️I AM NOT A SKY EMPLOYEE ▪️
This message was authored by Tim+Adams This message was authored by: Tim+Adams
Hi @Msdrury
Please switch off at socket, wait a min then back on and try again.
Could you do a Netflix Speedtest from the app on Stream?
 Open Netflix,
  1. From the Netflix homescreen, go left to open the menu.
  2. From the bottom of the menu, go right and select Get Help.
  3. Select Check your Network.
Thanks,
Tim
Sky Glass with Sky Live, Sky Stream & Sky Protect - FTTP 2Gbps
