Discussion topic: Can't control TV anymore - Sky Stream
This message was authored by: PortlandBill
Last week the voice control on my sky stream remote stopped working. Press the button, screen prompt comes up, but no response to my voice ("subtitles on/off" etc). So I went through the help suggestions on the app - no change. Ordered a replacement remote. Arrived this morning. Went through the process of pairing, multiple times but can't get it to turn the volume up or down (voice control is working) . The old remote always controlled the TV volume, and the soundbar volume, and turned the TV on and off (long press of remote power button). Doesn't work anymore. So, I call Sky. Spoke to a lady who told me my TV is not longer compatible. Seems odd, Ive not changed anything with the TV, no updates recently. I said we'll if that's the case, you're not giving me the service I need. She says she'll put me through to cancellations. Spoke to another lady in retentions who said "that doesnt sound right, let me talk to customer services". Put me on hold. 55 minutes later, still on hold. Gave up. Any ideas?
This message was authored by: martswain
Re: Can't control TV anymore - Sky Stream
My voice control stopped after the latest software update.
Solved by doing a RESTART through the settings menu.
Avatar for PortlandBill
Level 3 icon
Voice control is working fine now. It's the control of volume (and on/off) which is the main issue.
This message was authored by: Chloe-W22
Posted by a Sky employee
Hey @PortlandBill, before pairing the new remote you need to unpair the old one. Try these steps: https://www.sky.com/help/articles/setting-up-sky-glass-remote
Chloe-W22
Sky Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
Level 3 icon
Thanks, done that before pairing the new one.
  1. Still no volume control.
Keep trying, but in the meantime I've escalated your post for support from a Sky Expert. For information on how our Community Messaging service works, you can see here.
Chloe-W22
Level 3 icon
I spoke with the expert who couldn't get it working so I have been sent another remote to try. It arrived today.
Have tried installing it and it doesn't control the TV volume either. Still the same Sony Bravia TV that it used to work on.
Can I get more help?
This message was authored by: Jporch316
Hi @PortlandBill
im assuming you have gone through the various remote codes for your tv ? There a section in the settings for it
Level 3 icon
Yes, all 32 of them, twice.
I thought you may have !
which tv make and model do you have ?
Level 3 icon
Sony Bravia
