4
This discussion topic has been answered Discussion topic: Broadband Speed
This message was authored by: Ken4956
Broadband Speed
I need to know if Sky Broadband speed of 44Mbps will support Sky Glas or Sky Stream.
This message was authored by: Fothergill1 Answer
Re: Broadband Speed
Hi @Ken4956 As @BenJoBanjo says there a number of things that can effect your BB speed but just to add to his post the recommended minimum speeds received at your Glass or Puck (not at the router) are as follows:
HD = 25mbps
UHD = 30mbps
HD + 1 puck = 30mbps
UHD + 1 puck = 35mbps
This assumes there is nothing else using up your bandwidth.
Re: Broadband Speed
It should do. But it's impossible to tell without trying it really. There are several factors which can affect speed and stability of your broadband connection. I'd recommend starting off with a Sky Stream puck to check how well the streaming service works on your individual connection. Then, if you're happy, can add a Glass TV at a later date.
You may find it tricky to run both simultaneously with 4K streams - this would push your bandwidth possibly beyond its limitations.
Re: Broadband Speed
HD = 25mbps
UHD = 30mbps
This message was authored by: JAK29
Re: Broadband Speed
I have just transferred to Sky and I'm not getting the speeds advertised or of my previous provider
Re: Broadband Speed
What speed are you paying for and what speed are you receiving? Are you testing the speed actually arriving at the router or the speed being received on a device over WiFi?
