Discussion topic: Audio lag external speaker
This message was authored by: Niall23
Greetings,
Recently my Sky Stream suffers delayed audio with my external speaker. Key points:
1. The external Samsung speaker works fine apart from inside Sky Stream.
2. Sky Stream works fine with my tv speaker.
3. This is a recent issue i.e. only started happening over last few days.
Logic suggests a Sky puck update could be responsible. Is this a known issue? What's the best way to fix?
Re: Audio lag external speaker
@Niall23 please post how thecsystem is connected and which TV and audio system you have. It is worth experimenting  with different audio output settings on the puck to see if that helps.
@Niall23  For info I have removed the duplicate  post you accidentally posted in SKY Q as requested
Avatar for Niall23
Thanks for getting back to me.
Samsung 2023 QLED + S800B soundbar.
The issue persists both via HDMI and WiFi connections to the soundbar.
The issue persists both using Passthrough and PCM Stereo sound options inside Sky Stream.
