Discussion topic: Additional Location Letter
This message was authored by: CornishNick
Has anyone else had an email saying they're using their puck in an additional location when they're not? Says they'll charge an extra £26 if we don't stop....
Bude, Cornwall
Sky Stream
Jurassic Fibre 450mbps
Re: Additional Location Letter
@CornishNick  The only reason this is likely to happen is if the puck is on a different public IP to the others?
Are all your puck using the same network and broadband connection?
Avatar for CornishNick
Level 2 icon
Have failovers and various VPN setups for work (I support a few companies and can't ever be down for that reason) - could that be it?
Bude, Cornwall
Sky Stream
@CornishNick  Possibly
@CornishNick  If the puck has a different public IP then yes, you'll need to configure all the pucks to be using the one broadband connection/public IP.
I don't know what routers etc you're using but you should be able to configure the pucks to use a specific WAN at all times
Level 2 icon
Does that mean we're not allowed to use our second network to watch TV if the main one goes offline? Is there any way round this?
Bude, Cornwall
Sky Stream
@CornishNick  Yes & no,
If you have a backup line and the main one fails all pucks should failover to the same network, howevr I should note I can't confirm if this would be an issue or not.
What seems to be the issue at present is one of your pucks is using a different BB service to the other, you need to resolve that 1st.
If all pucks are on the same public IP you should be ok.
Level 2 icon
I didn't think the pucks could automatically join other (even if known) networks? They're all currently attached to the same wifi from what I can see....  one's on a 2.4Ghz SSID and others on the 5Ghz one but thats all.... just due to signal strength at that end of the house
Bude, Cornwall
Sky Stream
@CornishNick  If your using 2 broadband lines (you've said you have a failover) you will have 2 WAN ports being used on your hub, it is possible that one of the pucks has defaulted to the other wan, this is what you need to resolve.  Being connected over 2.4 or 5ghz wifi won;t be the issue.
How is the main line & failover configured?
On my dratek multi dual wan hub they have a setting for always on or failover, there should be a similar setting on your hub, if the failover is always on the other puck could be using this wan rather than your main wan.
Yes, that's almost certainly what's happening: the pucks have been logged by Sky as being active simultaneously behind different public IP addresses, which in most cases would indicate use at different physical locations.
Level 2 icon
@TimmyBGood @GD1
Thanks both! I'll have a think of how to sort this. It's a little openWRT router/access point that flips between the main fibre ISP (via it's wifi) and the backup (priority on speed I think). Fibre wifi isn't so great down that end of the house so I guess it's failing over more than I think, and I just don't notice when using the PC. It will only be affecting the one puck in the office when used as a spare room.
Unfortunately something more sophisticated isn't possible as we have a VERY locked down ISP router....
Nick
Bude, Cornwall
Sky Stream
this post got me thinking. The OP is clearly not using two pucks in two different locations, but the letter suggest if you are, the worse that will happen is you are charged £26? That a cheap second subscription if someone is on a full package and wanted to split it with a friend ??
@Anonymous  it doesn't mean customers can breach terms and conditions which is what they would be doing
I would also remind you of the community rules which prohibits discussion of ways to breach such terms and conditions
