14
This discussion topic has been answered Discussion topic: Activate sky stream
This message was authored by: Chiedu
Activate sky stream
I’m trying to activate my account but it states “oops there has been a problem” “call a sky expert”. I can't call now because of your working hours. Please help!!
This message was authored by: Fothergill1 Answer
Re: Activate sky stream
@Chiedu Welcome to the forum. This is a customer help customer public forum so you are not actually addressing Sky by posting here.  If you are not signed into your MySky account you will usually receive this Oops error  message but there can be other causes.
If you are not signed into your My Sky account sign in at https://www.sky.com/mysky
During setup you must also be using the same email that is registered to your account.
Once logged in go to https://www.sky.com/productsettings/streaming-tv/activate This is where you can enter your activation code that appeared on your screen during setup.
The following link is to a setup help guide:
https://www.sky.com/help/articles/setting-up-sky-glass-help
Hopefully this wil help 🤞
This message was authored by: Chrisd48
I did get my activation linked eventually. I had to reset the TV and router, (switching both off for a few seconds). Then I switched the router on, once that was running okay, I switched the TV and box and started the activation again and it worked at sky.com/activatenow. It could be the Internet explorer, maybe worth changing to a different one. I used the Sky app and got to customer service. It took a short while. I hope this works for others.
This message was authored by: AmyH81
Hi
Still waiting for a call from yourselves sky has thoroughly been reset still no active service
@AmyH81 wrote:
Hi
@AmyH81 FYI this is a community of other Sky customers and you aren't engaging with Sky Customer Services by posting here.
what is your issue and what did Sky say to you exactly when you last phoned them?
This message was authored by: Deptford01
Now let's continue
This message was authored by: Tracey80
Do you mean mediator I've had a week without my sky because you say you have cancelled I didn't your still charging me why
I forgot been with sky for 11+ years
@Tracey80  We are customers like yourself, you need to call Sky Customer Services.
If Sky is your mobile provider you can phone them by  dialling 150.
If it is not your provider follow this link https://www.sky.com/help/home and scroll down to need more help, click on this and you will see an 0333 phone number to use to call Sky. Unfortunately I cannot include the actual phone number as the forum filters will block it.
This message was authored by: Carolyn53
Entering g my sky puck code
??? Explanation, please.
This message was authored by: Dick+Turpin
It's a load of **bleep** they take the money from my account and their looking for me to pay again I should be looking at the channel now I rang sky yesterday and still nothing I want my money back
This message was authored by: Greenland
I'm having the same issue only the error message reads 'This page is restricted' every time I try to access the link above you e included in your reply and it's the same link the sky support lady text me and I tried whilst I was on the phone to her.
even she couldn't understand why it wouldn't work and we ran out of time so she's calling me back tomorrow but I've been trying again tonight but still says 'page is restricted 😓
This message was authored by: Manny7
I've got discovery plus & Wen I open the app it gives me every channel it's ment to except TLC Wen I try it takes me to try again or back wiçh both do nothing?
This message was authored by: JazTheTim
I don't remember ever doing this.
I have sky stream.  If I go into my MySky app it says awaiting activation & will auto update after 21 days
everything seems to be working fine tbh.
do I need to activate and where would I find the activation code
