Discussion topic: ADVERT FOR DRAMA FREEZING TV
Message posted on 15 Feb 2026 03:25 PM
Message posted on 15 Feb 2026 05:10 PM
Re: ADVERT FOR DRAMA FREEZING TV
@Kynanisme555 Does it happen when watching live tv, or just when using apps such as ITVX? Either way try two things. Go to Settings (use the voice button is easiest) go to System management, Resets & updates and chose App refresh. This takes a few minutes so wait for it to go back to the Home Screen. Then go back into the same settings but this time chose Restart. Again wait for it to reset and return you to the Home Screen. See if that fixes it for you
Message posted on 15 Feb 2026 05:19 PM
Is the image from "Betrayal" by any chance? If so, that is a known problem being worked on. I've no idea when it will be fixed but I've seen the same thing recently.
