Discussion topic: 2nd puck not connecting error on screen
This message was authored by: CDryden
The screen says
sorry because of a technical issue you're currently experiencing a limited service. Please be assured thaff to we're working hard to fix the problem
its been like that since everything was installed yesterday
this is the bedroom puck, the main one in living room is working fine
don't know what to do ?
Re: 2nd puck not connecting error on screen
Hi @CDryden
Unlike Q there isn't a main puck and secondary puck. Each device connects to your router / wifi. In the first instance try powering off at the mains for a few minutes. If this doesn't work, try swapping your pucks over and see if there are issues in the location.
Failing this we will need some more info like who is your ISP, what's the strength like where you are having issues etc.
MikeAlanR
@CDryden wrote:
The screen says
Do Sky even know there is an issue with an individual puck🤔
This is just a misleading error message?
