3
This discussion topic has been answered Discussion topic: Sky Store voucher using piggybank
This message was authored by: ajmillen
I am trying to purchase a sky store voucher using my rolled data but there is no option on the website to select "used 25g data...".  There is only a button that says "Add" but when I click this nothing happens.
I am currently on hold with Sky and have been for ages but getting no where with them!
Can anyone help please??  Do I have to roll my data to my sim to use it?  It only gives option to roll maximum 5gb of data.
TIA
Re: Sky Store voucher using piggybank
Does this guide help:
https://www.sky.com/help/articles/your-sky-piggybank
To get a Sky Store voucher:
  1. Go to the 'mobile accessories' section in the Sky Shop.
  2. Sign in with your Sky iD to see your available Piggybank rewards.
You can buy one Sky Store voucher at a time. To buy more than one, you'll need to place them as separate orders.
If this doesn't work try contacting Sky Store support via the luve chat:
https://www.skystore.com/help/contact-us
This message was authored by: popacatapetal
Unable to generate £10voucheer using piggy bank..
Only able to pay using credit card etc
Then as stated above use the live chat to contact Sky to see if they can help you with this, the link you need is in my previous post.
