This discussion topic has been answered Discussion topic: Sky Rental will not play
Message posted on 27 Feb 2021 09:27 PM
I downloaded Secret Garden to rent but it appears to be jammed. It will not play - I just get a blue screen and It will not delete.
Message posted on 27 Feb 2021 10:17 PM
Try deleting the film, then deleting it again from the deleted folder and then download it again.
Message posted on 28 Feb 2021 04:15 PM
Re: Sky Rental will not play
Thank you - I've managed to totally delete it so will now try downloading again! Many thanks for your help.
Message posted on 06 Mar 2021 06:26 PM
I have download The Secret Garden to rent in SD to watch last Saturday. It would not play just a blue screen.
Rang SKY they advised to delete, reboot the box and try again. I did as they suggested and have download again but still a blue screen.
Never had an issue downloading a film before. Does anyone have any othet ideas why it isn't working and what else I can try please?
Message posted on 06 Mar 2021 06:40 PM
@Sherry0967 When you deleted it, did you then permanently delete it from your Deleted Tab.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 06 Mar 2021 06:55 PM
Yes I deleted it from my deleted items as well.
Message posted on 06 Mar 2021 07:10 PM
I have already deleted and deleted from the folder and re loaded twice but still just getting the blue screen. I have also rebooted my box.
Message posted on 06 Mar 2021 07:35 PM
Further to my previous comments I have also done everything but Secret Garden will not play - there is obviously a problem with this particular film as all other film downloads have played.
Message posted on 06 Mar 2021 07:36 PM
It might be worth contacting the Sky Store team about this seeing that two of you are having the same problem so they can look into it for you:
https://www.skystore.com/help/contact-us
Message posted on 06 Mar 2021 07:40 PM
@JanePL Looks like there is a problem. I will contact sky and see what they say. Do you want to do the same? 😊
Message posted on 06 Mar 2021 07:43 PM
Yes, I have emailed them so if you contact them as well we may get a positive result!
Message posted on 06 Mar 2021 07:44 PM
Let us know how you get on when they reply to you, make sure you let them know of someone else who is having the same issue.
