11
This discussion topic has been answered Discussion topic: Sky Rental will not play
This message was authored by: JanePL
I downloaded Secret Garden to rent but it appears to be jammed.  It will not play - I just get a blue screen and It will not delete.
Re: Sky Rental will not play
Try deleting the film, then deleting it again from the deleted folder and then download it again.
Avatar for JanePL
Thank you - I've managed to totally delete it so will now try downloading again!  Many thanks for your help.
This message was authored by: Sherry0967
I have download The Secret Garden to rent in SD to watch last Saturday. It would not play just a blue screen.
Rang SKY they advised to delete, reboot the box and try again. I did as they suggested and have download again but still a blue screen.
Never had an issue downloading a film before. Does anyone have any othet ideas why it isn't working and what else I can try  please?
@Sherry0967 When you deleted it, did you then permanently delete it from your Deleted Tab.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Yes I deleted it from my deleted items as well.
I have already  deleted and deleted from the folder and re loaded twice but still just getting the blue screen. I have also rebooted my box.
Avatar for JanePL
Further to my previous comments I have also done everything but Secret Garden will not play - there is obviously a problem with this particular film as all other film downloads have played.
It might be worth contacting the Sky Store team about this seeing that two of you are having the same problem so they can look into it for you:
https://www.skystore.com/help/contact-us
@JanePL  Looks like there is a problem. I will contact sky and see what they say. Do you want to do the same? 😊
Avatar for JanePL
Yes, I have emailed them so if you contact them as well we may get a positive result!
Let us know how you get on when they reply to you, make sure you let them know of someone else who is having the same issue.
Answered - Go to Answer
