Discussion topic: Rewind/ffwd My library films
Message posted on 10 Jul 2022 06:03 PM
When I am watching a film from my Sky Store library, if i try to rewind or ffwd it does not work. The film carries on playing but in slo mo. If I press it again this continues. I then press pause or exit and nothing happens. Then about 2 minutes later it tries to do all the things I have requested all at once. I have tried pressing rewind and then just waiting, but then - by the time it finally reacts - it has gone way too far back. Then I have to ffwd, with exactly the same problems. I usually end up turning the film off.
Message posted on 10 Jul 2022 06:38 PM
Re: Rewind/ffwd My library films
Hi @Cass254
Although I haven't experienced that on Skystore- I recognise the same effect as you describe and I've had that on occasions when watching a recorded program
For me- I can resolve it by powering off my Sky box at the mains plug for around a minute - then power back on.
It does need a minute or so to allow internal components to discharge and reset themselves
I hope that works for you if you try it.
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Message posted on 10 Jul 2022 08:14 PM
Thank you Mike. Mine is a NOW box rather than a Sky box (probably should have mentioned that) but I will give it a try.
Message posted on 10 Jul 2022 08:19 PM
Let me know if it helps on Now TV @Cass254
by the way - when you are on this forum - if you want to tag someone in to a post, just press the @ key
a list of names involved in the thread will pop up and you can choose one from the list
Sky Q 2TB main box
LG CX6LA from 2020
