8
This discussion topic has been answered Discussion topic: No time to die problems
This message was authored by: RYates7
We were watching the new bond film 'no time to die' on skystore and got half way through and it stopped playing. Now can't access it at all and doesn't show on skystore. Has anyone else had this issue? Really frustrating...
This message was authored by: mike+simmonds Answer
Re: No time to die problems
Hi @RYates7
You must still be within your 48 hours
Try to find it by voice search or magnifying glass search.  If you find it and it won't play - delete it then delete it from your deleted items
then download it again - quickly - as you only have 48 hours from when you first pressed play
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Hi @RYates7
Sky Q 2TB main box
LG CX6LA from 2020
Avatar for RYates7
Ok I'll try that thank you 👍🏻
This message was authored by: Federica-C
Any joy @RYates7?
Federica-C
Community Manager
We're interested in your ideas for improving Sky Go, Sky Q & Sky Broadband.
Browse the latest customer ideas or add your own.
Avatar for RYates7
Hi, yes deleting the download and then redownloading worked. All solved thanks
This message was authored by: Boyohull
I can't see even rent it I click on the main screen to rent and it just shows the the other bond films it just vanishes 🤪🤪🤪
Hi @Boyohull
What Sky box are you trying to rent it on ?
How is it connected to your TV ?
Sky Q 2TB main box
LG CX6LA from 2020
A sky Q box
Other than some corrupted downloads @Boyohull I've not heard of any issues with Sky Q premiere rentals
Probably worth a power off at the plug on your box for at least a minute then power back on to see if that clears it
Other than that probably as good as anything would be a livechat with the Skystore team
https://www.skystore.com/n/hlch/help/contact-us/live-chat
Sky Q 2TB main box
LG CX6LA from 2020
Answered - Go to Answer
