Discussion topic: wires
This message was authored by: Stroma1
wires
when new tennants take over do they need to install new wires for their tv? or can they use existing wires?
Re: wires
If there is already a dish connected to
the building with the wires coming into
the room where their Sky Q box is then they can use these.
Avatar for Stroma1
Level 0 icon
Re: wires
Yes there is but the wires outside the building have fallen and now run across the windows
Re: wires
Hi @Stroma1
If you carry out a Home move through Sky then they will sort out your installation and reinstall whatever is necessary.
https://www.sky.com/moving-home
Re: wires
The dish and wires are owned by the householder - if they need 'repair' then you would normally need to pay.
As noted, a new install could cover it.
