Discussion topic: why not both
This message was authored by: SnoooTwo
why not both
Why can't you have Sky Q and Sky Stream in the same home. Is it a technical issue of subscription control
Re: why not both
@SnoooTwo
Sky has never permitted two generations of its products at the same address: there's no technical reason for this with Q / Stream that I can think of, but that's what they choose to do.
Re: why not both
AFAIK You can have Sky Q and NOW in the same home as they have separate accounting systems
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for SnoooTwo
Re: why not both
I have 3 mini boxes. I know you can only connect 2 at a time, but the third one I have will simply not connect. A Sky Enginner spen 4 hours at the home trying to connect last Saturday with no success. Yet the mini box not connecting is the nearest to the main Sky Q box and in the hot spot for the house Wifi, so thinking Sky Stream just to replace the failing mini box connection
Re: why not both
@SnoooTwo
Now you've confirmed you have Sky Q I've moved your thread from the Sky+ board.
Re: why not both
@SnoooTwo wrote:
...so thinking Sky Stream just to replace the failing mini box connection
As indicated, that won't be possible, I'm afraid.
Avatar for SnoooTwo
Re: why not both
not possible beacuse sky won't let two generation of products into one home?
Re: why not both
@SnoooTwo  Yes
how many mini boxes have been tried to replace the faulty one as it could be a fault with the box not your broadband
Avatar for SnoooTwo
Re: why not both
new mini box hooked on the weekend
Re: why not both
@SnoooTwo  if the replacement is also not connecting get back in touch with sky and tell them that you are not receiving the service your paying for and it needs sorting
given that Q hardware is loaned to you sky are obligated to sort out one way or another
Re: why not both
Have you tried moving a functioning mini box to the problem location?
