17
This discussion topic has been answered Discussion topic: which lead fits where?
This message was authored by: Morgan53
changed my tv and sky doesn't work
This message was authored by: Angel_Aka Answer
Re: which lead fits where?
@Morgan53 wrote:
SKY Q (light is on)
Connect an HDMI cable from the HDMI port on the back of the Q box to an HDMI port on the back of your TV.
Use your TV's remote control (not the Sky remote) to select the appropriate HDMI input source. You should now be able to see the output of the Sky Q box and continue to set it up if you have just replaced it.
If you don't see any output from the Q box, turn it off at the wall for a minute then power it back on and allow it to restart.
@Morgan53  There isn't much to go on
Changing your TV shouldn't affect broadband where you have posted
Do you have Sky+HD, Sky Q or Sky Stream?
Avatar for Morgan53
I think i've messed up where the leads go...
Can you answer the question that has been asked?
Avatar for Morgan53
SKY Q (light is on)
@Morgan53 wrote:
SKY Q (light is on)
@Morgan53
The connection between a main Q box and a television set is typically an HDMI cable going from the HDMI port on the Q box and HDMI #1 on the TV set.
Avatar for Morgan53
Do you know how to find the HDMI input source on my remote please?
What make of TV do you have? It's normally a button with a rectangle and and arrow pointing in to the centre of it from the left hand side. It'll say source or input on it.
This message was authored by: DaveDrizen
Alternatively if your Sky remote also controls your tv like tuning off  and volume ect. On some tvs if you press the home button to turn your tv on (instead coronal on/off button) ( that the button with little picture of a house on) on some TVs the tv will automatically go to the correct input of your Sky box
As it is just after changing  TV that they are having problem with, I doubt that the SKY remote is paired with it.
Good point
Avatar for Morgan53
Thanks everyone tried to pair the remote that doesn't work But I keep getting a 'weak or no signal message for the hdmi's even though I've inserted and reinserted any thought? Cheers
hi @Morgan53
A weak signal message will be from the TV's own tuner & not a message from/via  an HDMI input
With the SKy Q box switched on (green Led) try pressing the following keys on the SKY remote in sequence
Home 1 0 8 0 Home
Then use your TV's own remote again to try selecting the correct HDMI input
As @nigea99 indicates, that's referring to signal from an aerial, not an HDMI cable.
Answered - Go to Answer
