Discussion topic: what is socket for?
Message posted on 29 Mar 2023 03:21 PM
what is socket for?
Hi,
I have just moved house and am setting up my sky Q box and TV there is a wall anttenna socket and also a HDMI wall socket what would I use the HDMI socket for?
Message posted on 29 Mar 2023 03:35 PM
Re: what is socket for?
Hard to know. Is there another HDMI wall socket elsewhere in your new house? They might be linked.
Message posted on 29 Mar 2023 04:37 PM - last edited: 29 Mar 2023 04:38 PM
Is there any evidence of a similar socket in a location where a wall-mounted television could go?
For UHD it would have to be within three metres cable run.
Message posted on 29 Mar 2023 04:46 PM
yes there is the same wall socket in a bedroom next door.
Message posted on 02 Apr 2023 11:55 AM
Logic would tell me that the socket is to connect a hdmi soucrce into one end and hdmi out on the other end in the other room
LG 50UQ7006
Sony STR DN1020
Message posted on 02 Apr 2023 12:00 PM
@steve30x wrote:Logic would tell me that the socket is to connect a hdmi soucrce into one end and hdmi out on the other end in the other room
Logic tells me that if it was a new build either there will be no wires connected to it or the electrician will not have connected it correctly. I have never come across HDMI sockets like that but often Ethernet ones.
All you can do is to try it as though it was an extension lead and see if it will work.
Message posted on 02 Apr 2023 12:50 PM
Thanks for the help guys
Message posted on 02 Apr 2023 09:17 PM
@terry004 Did you arrange a move with Sky? If not, make sure you inform them as your obliged to inform them in the T&Cs.
Message posted on 03 Apr 2023 10:59 AM - last edited: 03 Apr 2023 11:00 AM
They certainly exist, and in some profusion: https://www.google.com/search?q=hdmi+wall+plates
Message posted on 03 Apr 2023 11:08 AM
Hi Mark they are the same as what I am talking a out confusing to know what it is for. Do you think you plug your TV into it.. ot to tecky so forgive me.
Message posted on 03 Apr 2023 11:29 AM
That's not very techie - we can do quantum entanglement if you like 😉
Yes it's just a way of neatly carrying HDMI signals between rooms. Source at one end, TV at the other. Assuming it's been wired up behind the wall.
Message posted on 03 Apr 2023 11:37 AM - last edited: 03 Apr 2023 11:41 AM
Source device (such as Sky Q box) plugged into the socket in one room, television plugged into the socket in the other room. Assuming there's actually HDMI cabling hidden in the wall between the two sockets, audio/video travels over it.
A housebuilder might install such a system where there's also built-in aerial or satellite dish cabling.
In theory this also means that (using a cheap HDMI splitter) you can have a television in each room showing synchronised content.
Message posted on 03 Apr 2023 11:40 AM
