Discussion topic: waiting for tv schedule
This message was authored by: Lexi4
tried re-booting but does not fix - message on for last 2-3 days
Re: waiting for tv schedule
@Lexi4
Try rebooting your broadband hub first, then do the main Sky Q box and then any mini boxes.
Avatar for Lexi4
unfortunately re-booting hub then skyQ box did not work
Hi @Lexi4
