Discussion topic: waiting for tv schedule
Message posted on 31 Dec 2025 05:49 PM
tried re-booting but does not fix - message on for last 2-3 days
Message posted on 31 Dec 2025 05:51 PM
Re: waiting for tv schedule
Try rebooting your broadband hub first, then do the main Sky Q box and then any mini boxes.
Message posted on 31 Dec 2025 07:24 PM
unfortunately re-booting hub then skyQ box did not work
Message posted on 31 Dec 2025 07:30 PM
Hi @Lexi4
